1991 accord problems
I have a 91 accord EX-R and have a few issues i need some help with.
1. Lately the clutch seems to not be "grabbing", and is not very smooth. In the last 6 months or so 3 or 4 times the car shudders like crazy when im starting from a complete stop. The car only has 126,000 kms and the clutch was replaced around 105,000.
2. When i bought the car it had an old alarm in it that eventually stopped working. Then the power locks quit. After replacing the alarm, the locks still dont work. WHen i push the switch i hear a "clicking" sound coming from the upper right hand corner of the driver door. Ive been told it may the actuator?
any help would be appreciated
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by campbell10 »</TD></TR><TR><TD CLASS="quote">I have a 91 accord EX-R and have a few issues i need some help with.
any help would be appreciated</TD></TR></TABLE>
1, you get your flywheel resurfaced when you replaced the clutch?
2, door lock actuator
When you remove the door panel there will be a control unit for the door locks, when you remove it and open it up you will find bad solder joints.
you are hearing the relay in the unit click but power is not passing to the lock actuator due to bad solder joints.
belairbrian
Sep 7, 2014 08:45 AM
2point6
Oct 2, 2007 08:20 AM
