d16z6 w/ y8 intake mani fitment and things needed
Old Mar 7, 2007 | 07:03 AM
1kleenef's Avatar
Default d16z6 w/ y8 intake mani fitment and things needed
wondering wat i need to do to mate the y8 manifold to the z6 head and ne sensors or other injectors, fuel rails. This is in a 91 sedan that is converted to obd 1. Ne help is greatly appreciated.
Old Mar 7, 2007 | 08:43 AM
HBK's Avatar
HBK
Default Re: d16z6 w/ y8 intake mani fitment and things needed (1kleenef)
It should be pretty straightforward. Map sensor is on the throttle body, so you can eliminate that vacuum line. Intake air temp sensor has to be plugged into your intake cause there is no slot for it on the IM. Other then that just run your coolant/vacuum lines and call it a day
Old Mar 7, 2007 | 10:24 AM
gnar kill's Avatar
Default Re: d16z6 w/ y8 intake mani fitment and things needed (HBK)
reuse your obd 0 injectors otherwise you will have to take out the resistor box
95civiclxx
Feb 8, 2011 09:53 AM
shawnperolis
11
Sep 2, 2010 11:42 AM
xparalandrax
Jun 21, 2006 01:55 PM
purple98ek
Sep 24, 2005 08:25 PM
MrTodd
Aug 1, 2002 10:07 PM
