which LSD for 500whp?? obx??
Old Mar 7, 2007 | 06:46 AM
teri_vti's Avatar
Default which LSD for 500whp?? obx??
hello i want to put an lsd in my transmission . its a b18c 500whp engine and ofcourse i want to improve my times....
which one do u suggest>???? or where to find?
anyone tried OBX lsds??
Old Mar 7, 2007 | 07:11 AM
boosted96teg's Avatar
Default Re: which LSD for 500whp?? obx?? (teri_vti)
ur gonna get ppl on here that say there junk. My experience with the obx LSD has been great. Set-up is LS/vtec turbo 619hp and 427 lb/tq. Never one problem with the tranny or LSd. Tranny is b16. I think u would like it.
Old Mar 7, 2007 | 07:19 AM
OceanStateTuning's Avatar
People have had mixed reviews about them, some good, some bad. Its your tranny. Seems to be most people only have problems when trying to remove the axles. H-T sponcers sell the real version for 835 so why spend half and take a risk of damaging your tranny?
Old Mar 7, 2007 | 08:04 AM
trickeng's Avatar
Default Re: which LSD for 500whp?? obx?? (OceanStateTuning)
OBX has proven to be a great buy. They did have there issues early on but most or all are taken care of.
Plus, diff's like Quaife or OBX (torsen type) are almost fully incased and don't tend to spray metal bits all through your tranny. So in most cases a broken diff doesn't hurt your tranny.
Old Mar 7, 2007 | 08:07 AM
fmfkid250's Avatar
who sells obx lsds?
Old Mar 7, 2007 | 03:26 PM
teri_vti's Avatar
will it help me improve my time as if i put a quaife in?
cuz the ITR lsd didnt help at all
i found it on ebay (the OBX) for 350-400$
who sells a quaife here?
em i got a GSR tranny, is it the same for b16 trannies also??
Old Mar 7, 2007 | 04:42 PM
turboedc2's Avatar
Default Re: (fmfkid250)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fmfkid250 &raquo;</TD></TR><TR><TD CLASS="quote">who sells obx lsds?</TD></TR></TABLE>
Tom at Camp1320...
Old Mar 7, 2007 | 05:12 PM
Boner_Ben's Avatar
Default Re: (turboedc2)
Just ordered my OBX lsd, we'll see how it holds up. I ran some good times open diff but looking to make alot more power this year. The LSD is different for a gsr/itr and ls/b16.
Old Mar 7, 2007 | 06:22 PM
Bakersfieldgsr's Avatar
Default Re: which LSD for 500whp?? obx?? (boosted96teg)
obx is good ive never herd of a problem happening to these.. and b16 tranny is the ****.
Old Mar 8, 2007 | 09:55 AM
teri_vti's Avatar
i also know the PHANTOM GRIP, its something u put in the OEM diferental.
http://cgi.ebay.com/ebaymotors...wItem
do you know which one is better?
phantom grip or OBX lsd , for drag racing always....
which one has a bigger percentage ?? (ITR lsd is around 25% i think)
Old Mar 8, 2007 | 10:54 AM
RaceProfessor's Avatar
Default Re: (teri_vti)
I haven't heard good things with the Phantom Grip unit but the OBX we've used on a LS trans and it works fine.
Old Mar 8, 2007 | 11:28 AM
Jason703Racing's Avatar
Default Re: which LSD for 500whp?? obx?? (Bakersfieldgsr)
i run a CTR tranny (oem lsd) i was thinking of going with a OBX
Old Mar 8, 2007 | 03:12 PM
12secEG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teri_vti &raquo;</TD></TR><TR><TD CLASS="quote">hello i want to put an lsd in my transmission . its a b18c 500whp engine and ofcourse i want to improve my times....
which one do u suggest&gt;???? or where to find?
I never been close to 500 whp cause i never own a turbo setup, but anyway on my old setup i use a b16 tranny with lsd, works just fine with my lsvtec.
Old Mar 8, 2007 | 03:49 PM
nonvtecallmotor's Avatar
Default Re: (12secEG)
I have never seen a diff. in times with a LSD.. B16-LS-Type-R all use the same diff. and the GSR is a diff unit. I have a Qauife in my car now and I wouldnt go half assed on a LSD.
Old Mar 8, 2007 | 04:41 PM
Boner_Ben's Avatar
Default Re: (nonvtecallmotor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonvtecallmotor &raquo;</TD></TR><TR><TD CLASS="quote">I have never seen a diff. in times with a LSD.. B16-LS-Type-R all use the same diff. and the GSR is a diff unit. I have a Qauife in my car now and I wouldnt go half assed on a LSD.</TD></TR></TABLE>
I'll show you
Old Mar 8, 2007 | 04:59 PM
RacerStev's Avatar
Default Re: (Boner_Ben)
Just be sure to take the OBX aprt and check it. I've found metal bits inside and
loose bolts holding it together.
Also just grind a 45 degree angle on the snap rings that hold the axle in place. This way they will come out agein. If you don't good luck..
steve
Old Mar 8, 2007 | 05:09 PM
Boner_Ben's Avatar
Default Re: (RacerStev)
Thats what I plan on doing, tearing it all down, cleaning it all, and putting it back together with proper torque specs. The new OBX diffs already fixed the problem with the stuck axles.
Old Mar 8, 2007 | 07:59 PM
BoostedJeff's Avatar
Joe went 9.8X on a OBX, he finally broke it last weekend after 300 or so passes on it
Old Mar 9, 2007 | 12:45 AM
teri_vti's Avatar
anyone else knowing something about phantom grip? i dont know if i should get this or OBX....
any minus fot it?
Old Mar 9, 2007 | 04:30 AM
RacerStev's Avatar
It really kinda easy, Phanton Grip is well, junk, OBX is a knock off of a good diff.
Old Mar 9, 2007 | 03:15 PM
DSMJim's Avatar
Default Re: which LSD for 500whp?? obx?? (trickeng)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trickeng &raquo;</TD></TR><TR><TD CLASS="quote">OBX has proven to be a great buy. They did have there issues early on but most or all are taken care of.
Plus, diff's like Quaife or OBX (torsen type) are almost fully incased and don't tend to spray metal bits all through your tranny. So in most cases a broken diff doesn't hurt your tranny. </TD></TR></TABLE>
Torsen and Quaife are not the same. Quaife is a helical gear. One difference will be 2.5:1 bias v. 4.5:1 bias. The Quaife almost guarantees traction during split traction events due to the amount of gears that are required to rotate in so many different axis. A torsen will wear in such that on a split, you can still do a 1-legger.
Quaife has a lifetime warranty even when raced so if you break it they fix it period (except in a talon cause our 3rd gear is known to explode ruining the diff lol) and you go back racing for nuthin. OBX may hold up but it's not warrantied lifetime and it's also not a Torque Biasing differential. Torsen tries to lock up, Quaife put the power to the wheel with grip being able to send almost 100% of the power to the outside wheel where torsen can't achieve anywhere near that.
Really their beauty is in road course and on the street not in drag. They will achieve a full lock up, my GTi always smoked both wheels even with the tires turned hard to one side.
In the end you get what you pay for. Dont cheap out on Tires, Brakes, Clutches or your Tranny. Everything else can be done cheapy and pretty well not matter.
Remember the rule...
GOOD FAST CHEAP, you can pick only two.
fast and cheap isn't good
good and cheap isn't fast
good and fast isn't cheap
Old Mar 9, 2007 | 03:43 PM
Default Re: which LSD for 500whp?? obx?? (DSMJim)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DSMJim &raquo;</TD></TR><TR><TD CLASS="quote">
good and fast isn't cheap</TD></TR></TABLE>
Old Mar 10, 2007 | 03:11 AM
teri_vti's Avatar
so quaife is better for drag events than OBX , where deos phantom grip stands though....
i wanna get the one that may help me improve my times
if phantom grip behaves like Honda LSD then i dont need it cuz it doesnt help me for 0-18 (its great on the street though)
Old Mar 10, 2007 | 05:25 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teri_vti &raquo;</TD></TR><TR><TD CLASS="quote">so quaife is better for drag events than OBX , where deos phantom grip stands though....
if phantom grip behaves like Honda LSD then i dont need it cuz it doesnt help me for 0-18 (its great on the street though)</TD></TR></TABLE>I've seen too many Phantom grips brake...
Old Mar 10, 2007 | 05:41 AM
DaveF's Avatar
break
