tranny motor mount?
Old Mar 7, 2007 | 05:21 AM
KickStart2323's Avatar
Default rear motor mount?
ok well i have a b16 in my 91crx si and the rear mount is toast, i got a replacement mount from hasport and my question is how hard is it to change it out...i try to do it a couple of weeks ago but i got stuck on how the mount itself came out...there is a triangle shape brackit that conects the tranny to the motor..do i just unbolt this brackit and the mount cmes out or do i have to take more stuff off to get to it...so any help would be nice..thanks...
Modified by hondarex2323 at 8:08 AM 3/8/2007
Old Mar 7, 2007 | 08:03 AM
1.6civicturbo's Avatar
Default Re: tranny motor mount? (hondarex2323)
you will have to suport the trany with a jack when you remove the mount. lowedr the jack so that u get room to remove the mount. ands just reverse everything you did to put the new one in
Old Mar 7, 2007 | 10:59 AM
Default Re: tranny motor mount? (1.6civicturbo)
thanks any more advice?
Old Mar 7, 2007 | 12:29 PM
RACINTWEEK's Avatar
theres not much to it, just loosen the t-bracket, put jack under the trans then take off the trans mount.
you might want to figure out why the mount got trashed in the first place otherwise you might end up buying a new one in the future
Old Mar 8, 2007 | 06:23 AM
Default edit Re: rear motor mount? (RACINTWEEK)
bumb
wasent the tranny mount but the rear mount i got the two mixed uped..
i started taking all the bolts out but i cant get this bracket apart...
.i was able to get 2 of the bolts that hold the mount to the sub frame loose but that damn bracket is in the way to get to the last bolt..so my question is dose this bracket even come apart or dose it somehow just pull out as a whole..
Modified by hondarex2323 at 8:07 AM 3/8/2007
obuhmyuh
26
Nov 5, 2008 02:30 PM
JDM-EJ1
Aug 1, 2005 12:10 PM
hothotpete
Nov 22, 2004 11:12 PM
mattL
May 25, 2004 12:32 PM
