anyone use the ZCspeed intake manifold adapter?
Old Mar 6, 2007 | 11:56 PM
thenick's Avatar
Default anyone use the ZCspeed intake manifold adapter?
Let's you adapt a standard D-series manifold to a DOHC ZC head. Anyone try this? Curious to see results with a Y8/Skunk2 intake manifold on a ZC using this adapter. Thanks.
http://zcspeed.com/adapterpage.htm
Old Mar 7, 2007 | 05:24 AM
sirtef9's Avatar
Default Re: anyone use the ZCspeed intake manifold adapter? (thenick)
there a good shop around here, trannys with them now as we speak
Old Mar 7, 2007 | 06:11 AM
civicflow's Avatar
Default Re: anyone use the ZCspeed intake manifold adapter? (sirtef9)
The Skunk2 manifold i have with my z6 was hitting the firewall til i smashed the firewall in. With the adapter and dohc zc head you would probally have to smash it in a lot on an ef. just my .02 cents
Old Mar 7, 2007 | 08:37 AM
thenick's Avatar
Default Re: anyone use the ZCspeed intake manifold adapter? (civicflow)
How about a Y8 then maybe with an LS throttle body? Anyone with a DOHC ZC knows we're fucked when it comes to TB options. Anyone else wanna chime in?
Old Mar 7, 2007 | 05:18 PM
thenick's Avatar
Old Mar 7, 2007 | 05:25 PM
STREETWERKZ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thenick &raquo;</TD></TR><TR><TD CLASS="quote">Let's you adapt a standard D-series manifold to a DOHC ZC head. Anyone try this? Curious to see results with a Y8/Skunk2 intake manifold on a ZC using this adapter. Thanks.
http://zcspeed.com/adapterpage.htm</TD></TR></TABLE>
or a JRSC.
Old Mar 7, 2007 | 05:31 PM
Crx Jimmy's Avatar
Default Re: anyone use the ZCspeed intake manifold adapter? (STREETWERKZ)
or a JRSC. </TD></TR></TABLE>
?? they DO make a ZC charger
Old Mar 7, 2007 | 05:35 PM
Default Re: anyone use the ZCspeed intake manifold adapter? (Crx Jimmy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">
?? they DO make a ZC charger</TD></TR></TABLE>
try finding one used though.
all i can come up with is new ZC kit - $1995 or used SOHC kit - $700 + $120 for the adapter.
do the math.
Old Mar 7, 2007 | 09:29 PM
thenick's Avatar
Exactly, that's why I'm trying to find people with this adapter. Does anyone think there would be a problem with injector location and atomization?
Old Mar 8, 2007 | 08:19 AM
thenick's Avatar
Old Mar 8, 2007 | 08:32 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thenick &raquo;</TD></TR><TR><TD CLASS="quote">Exactly, that's why I'm trying to find people with this adapter. Does anyone think there would be a problem with injector location and atomization? </TD></TR></TABLE>
i was thinking about the same thing.
not sure though. i've never used one of these.
it might be okay, ive seen ITB's with the injector firing right down the throttle body.
Old Mar 8, 2007 | 08:57 AM
djphonics's Avatar
do the math. </TD></TR></TABLE>
One just ended on Ebay last week. Nobody bought it. It was $1000 Buy It Now.
Old Mar 8, 2007 | 11:20 AM
thenick's Avatar
Default Re: anyone use the ZCspeed intake manifold adapter? (djphonics)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djphonics &raquo;</TD></TR><TR><TD CLASS="quote">
One just ended on Ebay last week. Nobody bought it. It was $1000 Buy It Now.</TD></TR></TABLE>
Streetwerkz, would I run into a problem using a SOHC kit with this adapter? Would I need a longer/custom belt? Any other problems I would encounter?
Old Mar 8, 2007 | 12:16 PM
jlicrx's Avatar
we came up with the adapter specifically to use the JRSC on the DOHC ZC and have done so without any problems - the JRSC is no longer available for the DOHC ZC - we bought the last one over a year ago (yeah, i know you can go the the website and it has it listed, but just try to buy one) - i do know that a Y8 manifold will fit using the adapter, but don't know about Skunk2 since we haven't tried it, but i don't think there is enough room without modifying the firewall - unless you have a lot of mods on the DOHC ZC, putting any kind of other than stock intake manifold (D16Y8, Skunk2, etc.) on it is probably going to hurt your performance
Old Mar 8, 2007 | 05:10 PM
thenick's Avatar
Default Re: anyone use the ZCspeed intake manifold adapter? (jlicrx)
Why do you say that -- is the DOHC ZC intake mani that good? I'm mostly considering the Y8/ LS TB combo for top end. My ZC needs more top end power and throttle body swaps are kind of limited as are intake mani's ...
Old Mar 8, 2007 | 07:05 PM
jlicrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thenick &raquo;</TD></TR><TR><TD CLASS="quote">Why do you say that</TD></TR></TABLE>
based on our experience over the last 7 years of working on and modifying the ZCs - have done around 40 ZC swaps
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote"> -- is the DOHC ZC intake mani that good? I'm mostly considering the Y8/ LS TB combo for top end. My ZC needs more top end power and throttle body swaps are kind of limited as are intake mani's ...</TD></TR></TABLE>
is your engine stock? if so, bigger throttle body and Y8 intake will slow it down
Old Mar 8, 2007 | 08:36 PM
MOE@Hyper16Valve's Avatar
so is the sohc JRSC still able to get ahold of new or used???I like new parts so can you still get THE JRSC new???MOE@HYPER16VALVE...
Old Mar 9, 2007 | 07:28 AM
jlicrx's Avatar
Default Re: anyone use the ZCspeed intake manifold adapter? (MOE@Hyper16Valve)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MOE@Hyper16Valve &raquo;</TD></TR><TR><TD CLASS="quote">so is the sohc JRSC still able to get ahold of new or used???I like new parts so can you still get THE JRSC new???MOE@HYPER16VALVE...</TD></TR></TABLE>
JRSC for the DOHC ZC is not available, but is still available for the SOHC D-series
Old Mar 9, 2007 | 07:59 AM
i posted for a SOHC motor can the JRSC still be able to get new if you cant get the JRSC new then this adapter plate works to convert the DOHC manifold to use the SOHC manifold Just wondering what would the benefits be for the DOHC I have an extra ROVER motor and wanted some type of input I sure u know what this adapter does it should allow you to use SOHC race parts on a DOHC motor right ???MOE@HYPER16VALVE...
Old Mar 9, 2007 | 03:56 PM
Streetwerkz, would I run into a problem using a SOHC kit with this adapter? Would I need a longer/custom belt? Any other problems I would encounter?</TD></TR></TABLE>
maybe a longer belt. that isnt a problem at all though.
Old Mar 9, 2007 | 07:02 PM
crxrocks's Avatar
I don't post much on HT but am around other places. I have seen this adapter plate and it is a really nice piece. I have in fact, ran a similar plate to mount a SOHC JRSC to a DOHC ZC and it worked out perfectly.
+1 to the folks at ZCSpeed - great guys.
Old May 27, 2007 | 09:07 AM
thenick's Avatar
Default Re: (crxrocks)
Is this piece thick enough to warrant extended intake manifold studs when using a Supercharger?
Old May 27, 2007 | 02:41 PM
jlicrx's Avatar
Default Re: (thenick)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thenick &raquo;</TD></TR><TR><TD CLASS="quote">Is this piece thick enough to warrant extended intake manifold studs when using a Supercharger?</TD></TR></TABLE>
the studs for the manifold screw into the adapter plate and the adapter plate bolts to the head with allen head bolts that end up behind the manifold - it comes with all of the bolts and studs
Old May 27, 2007 | 05:04 PM
Default Re: (jlicrx)
i sent you the link for the hondata gasket and extended manifold studs earlier today.
i personally would buy them because i have used hondata gaskets with good results on the JRSC setups. but the factory studs are really short for the thick gasket.
ef3Hatch
20
Apr 29, 2020 11:33 PM
Mr. Winky
Sep 7, 2008 11:26 AM
Fuzzy Rhubarb
Dec 22, 2007 07:44 PM
The Hooligan
Mar 19, 2004 08:43 PM
Jeff_G
Jun 10, 2002 08:26 AM
