Vtec not firing!!!
Changed my o2 sensor and put some oil in it. But still no vtec. Its not wanting to engage. What should i be looking for. I have a oil leak but dont know if that would cause it not to fire.
well, if you have an oil leak, could be that you're not building enough oil pressure. If the ECU can't get the pressure that it wants, it won't let VTEC engage.
I would imagine though, that you'd have a CEL if that were the case.
i trade my 240 for this car and its got some oil leaks that need to be fixed but i cant hear vtech when i take it all the way to 8. I looked at the ecu and its a p28. dont know if its chipped
B18c has dual runners - on stock VTEC point should be 4.4 - 4.6k rpm for the first and 6k rpm for the second. This should still be audible if its stock (mine was, at least).
If you have swapped engine in, ensure that ecu (p28) and wiring is connected and functioning correctly. Hate to join the bandwagon, but have you got the right ecu ..?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crowder13 »</TD></TR><TR><TD CLASS="quote">turbo'd, intake manifold, exhaust</TD></TR></TABLE>
wait....you're turboed? what are you using for engine management?
thats why you can't hear it... turbo would muffle it does it rev all the way to 8200? and keep getting faster after 5000?
B18c1, 94 integra ls body, p28 ecu, recently had a turbo on it and i just stripped it off tonight, so i should be able to hear it after it goes back to stockish form
