HELP WITH 96 CIVIC SWAP OB2 CAR WITH OBD1 MOTOR
Old Mar 6, 2007 | 08:49 PM
nyfire52fighter's Avatar
Default HELP WITH 96 CIVIC SWAP OB2 CAR WITH OBD1 MOTOR
I have a 1996 honda civic hatch and want to do a 95 b16(friend has it for cheap). I need to stay emissions legal in new york and want to know what to do. i'm goin to be using a 96 b16 ecu and a 95 b156 motor. I need to know what i need to make this happen if possible so i can get an inspection and everything be good.
Old Mar 6, 2007 | 10:09 PM
hatchi's Avatar
Default Re: |$|$|$| HELP WITH 96 CIVIC SWAP OB2 CAR WITH OBD1 MOTOR|$|$|$| (nyfire52fighter)
you will need obd2 alternator, distributor, injectors. reuse your engine harness and add some plugs
Old Mar 7, 2007 | 04:41 PM
Default Re: |$|$|$| HELP WITH 96 CIVIC SWAP OB2 CAR WITH OBD1 MOTOR|$|$|$| (hatchi)
but what plugs do i need and wat am i gonna have to wire up
Old Mar 7, 2007 | 04:53 PM
DelSolLou's Avatar
Make a sub harness If you don't know what your doing. Go to a performance shop and learn. Make a sub harness
Old Mar 7, 2007 | 04:54 PM
2080EK's Avatar
New User
Default Re: |$|$|$| HELP WITH 96 CIVIC SWAP OB2 CAR WITH OBD1 MOTOR|$|$|$| (DelSolLou)
In most states using a motor thats older then the car is illegal and wont pass visual on the smog side. Just FYI.
Old Mar 17, 2007 | 09:26 PM
Default Re: |$|$|$| HELP WITH 96 CIVIC SWAP OB2 CAR WITH OBD1 MOTOR|$|$|$| (2080EK)
so is it possible
bumpp
50trimmed
Mar 7, 2011 09:12 PM
hollywood96ex
Jan 30, 2009 01:56 PM
Shaar
Jun 14, 2007 09:59 AM
jdmEK209
May 24, 2006 02:03 PM
perfecttiming
Oct 22, 2004 06:17 AM
