Oil gauge on d16...
Old Mar 6, 2007 | 06:10 PM
danny_civic97's Avatar
Default Oil gauge on d16...
Yo!! I just bought the oil gauge but where does the sender unit connect to?
Old Mar 11, 2007 | 09:59 PM
ALLMOTORCRX20's Avatar
Default Re: Oil gauge on d16... (danny_civic97)
The way that most people do it is remove the oil pressure sensor in the back of the block and buy a " T " connection at a hardware store and connect it there. One side of the T to the oil pressure sensor and the other side to your sender for the gauge.
I just bought a sandwich plate and connected my sender there.
It's up to you.
Old Mar 12, 2007 | 01:00 PM
Crazydave's Avatar
Default Re: Oil gauge on d16... (ALLMOTORCRX20)
do no hang the oil pressure sending unit off the block.
Instead run a short line off the block (make sure to get the correct adapter...it's a 1/8 bspt thread)
then tee off to the pressure sender and to the pressure switch.
It's much easier though to get an sandwich plate. those will have a 1/2" npt , and your sender should have come with 1/2 npt adapter to whatever your sender uses.
(it's much cheape to replace a 1/2 npt to sending unit adapter than to fix your block)
Built4Battle
Nov 2, 2011 11:39 AM
afplayboy17
Oct 6, 2007 10:39 AM
itsJDMyo
Feb 21, 2006 11:36 AM
Alstare
Sep 5, 2005 03:10 PM
doublejz
Jan 3, 2004 03:15 PM
