will a 91-95 legend alternator work in a obd1 teg?
Old Mar 6, 2007 | 06:02 PM
efyou's Avatar
Default will a 91-95 legend alternator work in a obd1 teg?
on 3geez.com a forum for old school accords, this is a mod able to be done as a cheaper way for a high output alternator since the legend amps are like 110 stock as opposed to the accords 65. the only modification needed for it to work is some washers on the bracket to align it fine, a longer bolt, and i think bigger gauge wire to handle the higher amps....
so as long as the connectors are the same, i wouldn't see a problem, even then i can always rewire it to work, what do you think?
Gamma Ray
Aug 18, 2010 07:17 PM
hondachris1994
14
Jun 27, 2006 03:40 AM
. M i c h a e l
Nov 28, 2005 07:22 PM
Creamies
Oct 13, 2004 08:27 PM
