OBD SPEED SENSOR
i dont know if this has been posted but i couldnt find it..
im converting a 92-93 ls tranny to a obd1. what speed sensor do i use?? can i bolt on the sohc speed sensor?? thanks
92-93 ls tranny is OBD 1. What are you swapping it into? If it has a Electrical connector on it and so does your car just connect them. If It has a Cable type Speed sensor then yes you can use a d series electrical VSS in it.
