when rebuilding what seals/gaskets do i need?
Bottom end kit only includes the following...
*oilpan gasket
*front crank seal
*rear crank seal
*strainer gasket
*water pump gasket
There's still more that is needed.. but figure if you buy a TOP and BOTTOM end gasket set, then you are alright.
*oilpan gasket
*front crank seal
*rear crank seal
*strainer gasket
*water pump gasket
todapower
Sep 10, 2003 10:17 PM
