Painting alloy rims
Old Mar 6, 2007 | 03:33 PM
sony224422's Avatar
Default Painting alloy rims
I picked up some rims with tires, but there uglyyyyyyyy.
So, is it okay to sand them down and then paint them the color i want. and do i want to clear coat them when im done painting them to keep the paint on them?
Old Mar 6, 2007 | 04:05 PM
Simactive's Avatar
Default Re: Painting alloy rims (sony224422)
Everything is possible just remember that after you paint them them will be subjected to high then normal heat becuase from the regular heat of the seats and then the heat dissipated from your brakes going on and off. They provide some generase heating if used in City driving. just beware of that, also i would only do the outside, leave the inside alone =P IMO anyways, if anything make a rough surface an paint of the paint there? just a thought.
Goodluck post some pics and lets see what it looks like.
Old Mar 6, 2007 | 04:15 PM
cityslicker1606's Avatar
Default Re: Painting alloy rims (Simactive)
did you drop out in 5th grade?
Old Mar 6, 2007 | 04:29 PM
Twixle's Avatar
ate my pixel
Default Re: Painting alloy rims (cityslicker1606)
Good thread on this topic. https://honda-tech.com/zerothread?id=1356908
Old Mar 6, 2007 | 04:40 PM
sony224422's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Simactive &raquo;</TD></TR><TR><TD CLASS="quote">Everything is possible just remember that after you paint them them will be subjected to high then normal heat becuase from the regular heat of the seats and then the heat dissipated from your brakes going on and off. They provide some generase heating if used in City driving. just beware of that, also i would only do the outside, leave the inside alone =P IMO anyways, if anything make a rough surface an paint of the paint there? just a thought.
Goodluck post some pics and lets see what it looks like.</TD></TR></TABLE>
wtf.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accord2021 &raquo;</TD></TR><TR><TD CLASS="quote">Good thread on this topic. https://honda-tech.com/zerothread?id=1356908 </TD></TR></TABLE>
thanks man. Those are alluminum but hopefully it will work the same
Old Mar 6, 2007 | 04:56 PM
Twixle's Avatar
ate my pixel
tell me more about this custom cam, I'm intruiged.
Old Mar 7, 2007 | 03:52 AM
toyomatt84's Avatar
Sanji
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sony224422 &raquo;</TD></TR><TR><TD CLASS="quote">
wtf.
thanks man. Those are alluminum but hopefully it will work the same</TD></TR></TABLE>
You do know that the term "alloy" is most commonly referring to "Aluminum alloy", right? The only other option is Magnesium alloy, and I doubt you're referring to those.
dannyem1
Aug 30, 2009 09:44 PM
ITR0952
Mar 2, 2005 02:40 PM
PurpleGsR00
May 28, 2002 12:59 AM
PoWeRBaN_PaNdA
Apr 30, 2002 11:01 PM
