alarm system going off when unarmed
Old Mar 6, 2007 | 02:58 PM
smcowman's Avatar
Default alarm system going off when unarmed
hey guys...i got a 98 accord lx and the alarm system has been going off without any kind of prompting. it goes off without being set. does anyone know where i can pull a fuse and where it is? i went through the driver/passenger side door fuses and under the hood and didnt see any alarm system fuse. any help is appreciated...thanks in advance
Old Mar 6, 2007 | 05:29 PM
The-Kid's Avatar
If it's after market, check the cables that are going to the battery. Maybe OEM does that too.
Old Mar 6, 2007 | 05:55 PM
philadd's Avatar
Default Re: (The-Kid)
If you have the optional Honda alarm, there's 3 different inline fuses hidden somewhere under the dash, and it could be on either the driver's or passenger side.
Fuse 1 will have a white wire leading into it, and a white/blue leading out.
Fuse 2, white and then white/red.
Fuse 3, yellow and then yellow/blue.
Fuse 1 should lead to the keyless/security system control box. Pulling this fuse may possibly disable the alarm system.
Fuse 2 leads to an unlock relay. <U>Pulling this fuse will not help</U>.
Fuse 3 leads to the control box and basically tells it when the key is turned to "ON". <U>Don't pull this fuse</U>.
Unfortunately, I can't help you find these fuses. I have absolutely no idea where they are. If the remote to your alarm doesn't say "Honda", then none of this will apply to you anyway.
Oh, and for those that are wondering, EX models are wired completely different. There are no fuses you can pull to disable the alarm.
Dropmy Si
Honda Civic (2006 - 2015)
Oct 2, 2008 10:31 AM
umar74
Honda Civic (2001 - 2005)
10
Sep 17, 2008 12:56 AM
vietjdmboi
Audio / Security / Video
Jun 25, 2004 09:18 PM
SlamMan
Jun 15, 2003 12:00 AM
