Intercooler size for crx.
Old Mar 6, 2007 | 01:58 PM
ILcrxsi1's Avatar
I tell doctors what to do
Default Intercooler size for crx.
What size's do you guys use? How much hacking is required for that size. Post pics if you want. Maybe this can turn in to a FAQ thread.
Old Mar 6, 2007 | 02:07 PM
Ermil's Avatar
Default Re: Intercooler size for crx. (ILcrxsi1)
What turbo are you running?
Old Mar 6, 2007 | 02:10 PM
ILcrxsi1's Avatar
Default Re: Intercooler size for crx. (Ermil)
T3/T4, not yet though. I'm going to start a build thread soon. This thread isn't really about efficiency though, it's more like a thread about intercooler fitment in crx's and EF's in general.
Old Mar 6, 2007 | 02:39 PM
RACINTWEEK's Avatar
26x8 cores are easily fit into our cars, and can support a good bit of power.
you will have to hack the support and the cover though, not difficult
Old Mar 6, 2007 | 03:24 PM
danmdevries's Avatar
Default Re: Intercooler size for crx. (RACINTWEEK)
That intercooler ^
Is this one:
In front of one of my EG's for reference:
I gave it to him cause I thought there was no way in hell that I could ever fit it in a little civic. He got it to fit WITH a bumper. Buuut... I think that's the absolute largest you could possibly put on there.
Old Mar 6, 2007 | 05:33 PM
square_1's Avatar
Default Re: Intercooler size for crx. (danmdevries)
Get the intercooler from an eagle talon... About the size of a heater core. hahah.... No, don't do that. I don't have a turbo but I see them all around with a decent sized intercooler in stock bumpers. Just some front end cutting required.
Old Mar 6, 2007 | 09:57 PM
ILcrxsi1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by danmdevries &raquo;</TD></TR><TR><TD CLASS="quote">
</TD></TR></TABLE>Good stuff. That's the kind of posts I'm looking for
Old Mar 7, 2007 | 01:43 AM
garageEF's Avatar
mitsubishi starion/dodge conquest intercoolers fit very well
Old Mar 7, 2007 | 03:13 AM
Autoworks's Avatar
Default Re: Intercooler size for crx. (garageEF)
27x6x2.5 fit with an unmodified bumper support.
Old Mar 7, 2007 | 04:33 AM
ILcrxsi1's Avatar
Default Re: Intercooler size for crx. (Autoworks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Autoworks &raquo;</TD></TR><TR><TD CLASS="quote">27x6x2.5 fit with an unmodified bumper support.</TD></TR></TABLE>That's what I've heard. I was planning on getting that size for that reason. It isn't really hard to cut a bumper support though.
Old Mar 7, 2007 | 05:01 AM
Autoworks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ILcrxsi1 &raquo;</TD></TR><TR><TD CLASS="quote">That's what I've heard. I was planning on getting that size for that reason. It isn't really hard to cut a bumper support though. </TD></TR></TABLE>
I use them all the time, got a few 27x9x2.5s I'm about to put on EF's as well.
Old Mar 7, 2007 | 05:13 AM
ILcrxsi1's Avatar
I use them all the time, got a few 27x9x2.5s I'm about to put on EF's as well.</TD></TR></TABLE>where do you get them from?
Old Mar 7, 2007 | 07:04 AM
Andy R's Avatar
Old Intercooler design:
Construction of new intercooler:
Comparison of the two IC's. The new core is 27" x 6" x 3" as apposed to the 17" x 9" x 2.5" You should also take note that the path of the charged air now travels top to bottom with a shorter fin path which is designed for lower pressure drops and higher cooling efficiency.
New bumper support design in middle stages. There will be 4 mounting points (2 @ original support mounting points, and 2 @ a newly made lower point). The IC will get two more brackets made to attach to the lower bar as well. The actual bumper will mount to the bracket that is bolted between the headlamp supports and will also have additional mounting points to keep it securely in place. IC ends have NPT bungs welded in for air temperature monitoring at both inlet and outlet.
Mocking up charge pipe to IC inlet. 2.25" Aluminum piping:
Old Mar 7, 2007 | 07:19 AM
89efDUSTY's Avatar
sorry to thread jack but does anyone run a side mount on a crx?
Old Mar 7, 2007 | 07:33 AM
JustAnotherRex's Avatar
Default Re: Intercooler size for crx. (89efDUSTY)
I've seen it done. I don't remember where now, with a bit of looking I'm sure it could be found. The small little Eclipse IC was used near one of the fake-ducts (that was cut) in the bumper on a Rex though. I believe the setup was for auto-x and extremely low boost though.
Old Mar 7, 2007 | 09:03 AM
ILcrxsi1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89efDUSTY &raquo;</TD></TR><TR><TD CLASS="quote">sorry to thread jack but does anyone run a side mount on a crx?</TD></TR></TABLE>It seems pointless. It would be harder to run the piping and it wouldn't cool as well as a frount mount.
Old Mar 7, 2007 | 09:17 AM
ESP-net
Guest
Posts: n/a
I have a few questions:
28"x5x3" (overall) could it fit in the crx bumper 90-91 with no trimming at all air ducts etc?
I may even go down to a 2.5" thick if space is tight...turbos 18g just boostin 7 psi
Old Mar 7, 2007 | 09:41 AM
Autoworks's Avatar
Default Re: Intercooler size for crx. (ESP-net)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ESP-net &raquo;</TD></TR><TR><TD CLASS="quote">I have a few questions:
I may even go down to a 2.5" thick if space is tight...turbos 18g just boostin 7 psi</TD></TR></TABLE>
You will have to trim the backside of the bumper, but can retain the grills. It will still fit perfectly fine.
hells yeah I love it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ILcrxsi1 &raquo;</TD></TR><TR><TD CLASS="quote">where do you get them from?</TD></TR></TABLE>
PM sent
Old Mar 7, 2007 | 09:46 AM
Slystone's Avatar
clean and simple for me!
Old Mar 7, 2007 | 09:53 AM
89efDUSTY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ILcrxsi1 &raquo;</TD></TR><TR><TD CLASS="quote">It seems pointless. It would be harder to run the piping and it wouldn't cool as well as a frount mount.</TD></TR></TABLE> not pointless if its free...and yes it will be low boost like 7 psi on a t25
Old Mar 7, 2007 | 09:58 AM
ILcrxsi1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89efDUSTY &raquo;</TD></TR><TR><TD CLASS="quote"> not pointless if its free...and yes it will be low boost like 7 psi on a t25</TD></TR></TABLE>But technically wouldn't the t25 create more heat because it's a small turbo, and make a better intercooler more necessary?
Old Mar 7, 2007 | 09:59 AM
ILcrxsi1's Avatar
Default Re: Intercooler size for crx. (Slystone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slystone &raquo;</TD></TR><TR><TD CLASS="quote">clean and simple for me!
</TD></TR></TABLE>What size? Any cutting required?
Old Mar 7, 2007 | 10:38 AM
Autoworks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ILcrxsi1 &raquo;</TD></TR><TR><TD CLASS="quote">What size? Any cutting required?</TD></TR></TABLE>
guessing 27x5.5x2.5 from the looks...if not it's very close to it.
Old Mar 7, 2007 | 11:27 AM
Mr.Death's Avatar
Here's what I'm using.
26 3/4" L x 6 1/4" H x 3 1/2" D, supports 350hp.
Old Mar 7, 2007 | 11:58 AM
143MYVTECEF's Avatar
Default Re: Intercooler size for crx. (Mr.Death)
What about the DSM side mounted intercoolers??
