Search Failed: Removing Hubs
Old Mar 6, 2007 | 12:28 PM
92civicfreak's Avatar
Default Search Failed: Removing Hubs
i have been thinking of doing the DA knuckle swap. & i am assuming that the axles from my d tranny will not just slide right into the hubs of the DA.... so, how hard is it to get the hubs out of the knuckle/do they have to be pressed in/out?
Old Mar 6, 2007 | 12:44 PM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: Search Failed: Removing Hubs (92civicfreak)
They have to pressed in/out.
Old Mar 6, 2007 | 02:26 PM
PACT man's Avatar
Default Re: Search Failed: Removing Hubs (wiZCo)
Slide Hammer...
Old Mar 6, 2007 | 02:35 PM
RACINTWEEK's Avatar
Default Re: Search Failed: Removing Hubs (PACT man)
if you have an Si or DX your axles will fit just fine.
if you have an HF or STD switch to Si axles when you swap to DA knuckles. no need to even pull the hubs(unluss you are getting new bearings)
Old Mar 6, 2007 | 02:42 PM
so i can use my dx/si axles that i have in there now in the DA hubs?
Old Mar 6, 2007 | 03:37 PM
VtecSyndrome's Avatar
Default Re: (92civicfreak)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92civicfreak &raquo;</TD></TR><TR><TD CLASS="quote">so i can use my dx/si axles that i have in there now in the DA hubs?</TD></TR></TABLE>
yes
dynamitezz
15
Aug 14, 2010 10:25 AM
soodominican
11
Jan 26, 2010 09:00 AM
crxrider07
Sep 9, 2008 12:00 PM
GsrTurboCRX88
Feb 19, 2007 02:52 AM
vegaskurt
Jan 20, 2005 08:13 AM
