cleaning motor
Old Mar 6, 2007 | 11:25 AM
dkrex001's Avatar
Default cleaning motor
what is the easiest way to clean a motor that is in a car.
Old Mar 6, 2007 | 11:26 AM
MagnaniEG6's Avatar
Default Re: cleaning motor (dkrex001)
spray can of engine degreaser its been cover search it please
Old Mar 6, 2007 | 11:27 AM
wiZCo's Avatar
Stouts 'n' Scotch
Simple Green and a wire brush. Then hit it with some tire shine and you're golden. Make sure to cover up your battery, air filter and distributor before hand.
Old Mar 6, 2007 | 11:28 AM
dkrex001's Avatar
Default Re: cleaning motor (MagnaniEG6)
searching is failing right now
MagnaniEG6's Avatar
I heard steam cleaning works also
Old Mar 6, 2007 | 11:29 AM
Ass$nyper's Avatar
Pirate General...YARRRR
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wiZCo &raquo;</TD></TR><TR><TD CLASS="quote">Simple Green and a wire brush. Then hit it with some tire shine and you're golden. Make sure to cover up your battery, air filter and distributor before hand.</TD></TR></TABLE>
Takes 20 seconds looks like hours of work, trust me I've done it with paper towels and armor all, it really does look the same and takes 20 times longer.
I would detail peoples bays for 10 bucks back in hs after I learned simple green trick
Old Mar 6, 2007 | 11:32 AM
MagnaniEG6's Avatar
Default Re: cleaning motor (Max The Amazing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Max The Amazing &raquo;</TD></TR><TR><TD CLASS="quote">
I would detail peoples bays for 10 bucks back in hs after I learned simple green trick </TD></TR></TABLE>
Im going try that
Old Mar 6, 2007 | 12:08 PM
wiZCo's Avatar
Stouts 'n' Scotch
trust me I've done it with paper towels and armor all </TD></TR></TABLE>
I'm sure you hated life after discovering Simple Green. I know the feeling though, the first time I tried it was with U-Haul truck wash and a small brush . Then I discovered the SG y0 and I can clean my bay at a moment's notcie.
Old Mar 6, 2007 | 12:16 PM
dohc_profile's Avatar
i took degreaser from work... covered up my battery, air filter, and distributor. covered everything eolse in the degreaser, and sprayed it down with engine cleaner at the DIY car wash.
mynameizstitch
Jul 3, 2009 09:24 PM
VTECROAR96typeR
Jun 1, 2009 12:07 AM
Shaynepolevault
Nov 11, 2007 12:45 PM
Martingtrco
May 27, 2005 07:46 PM
Paprika
Nov 24, 2004 08:20 AM
