quick queston, search does not work: dc and eg lca's (factory) interchangeable?
Old Mar 6, 2007 | 10:49 AM
integraXTC's Avatar
Default quick queston, search does not work: dc and eg lca's (factory) interchangeable?
THe parts numbers are off, but everyone alsways says they're interchangeable.
I have a 99 gs w/ abs, so I need some rear lca's w/ abs bracket holes and sway mounting too. I work at a honda dealership, so I can order the civic lca's but not if they're not the same.
quick help thanks.
Old Mar 6, 2007 | 11:24 AM
integraXTC's Avatar
I need the help before I go to work guys.
Old Mar 6, 2007 | 11:36 AM
soundFX's Avatar
Default Re: quick queston, search does not work: dc and eg lca's (factory) interchangeable? (integraXTC)
i know eg and dc coilovers are itnerchangeable. im sure the lcas are too if the coilovers are. not exactly sure about the lcas tho but im thinking yes.
Old Mar 6, 2007 | 11:37 AM
soundFX's Avatar
Default Re: quick queston, search does not work: dc and eg lca's (soundFX)
i can just sell u some gsr lcas and then u dont have to worry about the unknown.
Old Mar 6, 2007 | 11:41 AM
integraXTC's Avatar
well, I ordered some from an acura dealer online, but since I work at honda I could have them in 2 days tops and get a refund for that other online purchase.
Old Mar 6, 2007 | 11:44 AM
Mt3c's Avatar
25 Year Member
Default Re: (integraXTC)
yes, interchangable as long as you don't car about abs mounting holes.
zip ties work ok.
though you may want to look at lca's from the EX sedan, I believe that model may have abs.
Old Mar 6, 2007 | 11:49 AM
integraXTC's Avatar
Default Re: (Mt3c)
well the 2dr ex has abs, and so does the 4dr ex abs. But part numbers don't match.
is anyones's search feature working? mine says error.
Old Mar 6, 2007 | 12:05 PM
Mt3c's Avatar
25 Year Member
ok, just looking at the diagram, lca look the same. EX models have abs lines same/similar to integras.
bushings come up different part numbers which i'm willing to bet, is the reason the lca come up different p/n. They will be interchangable though, just not sure which bushing is harder.
EX
52360-sh3-g21
52350-sh3-g21
52365-sh3-000 (bushing)
Integra
52350-sh3-g31
52360-sh3-g31
52365-sk7-a02 (bushing)
Old Apr 17, 2011 | 08:32 AM
PDT1980's Avatar
I also need to replace my LCA -on my '95 del sol (VTEC) and wondering if an Integra ('94 -'01) one will fit?
while searching around I found that the '96 del sol shares the same LCA part# as the Integra, but the '95 del sol matches only a '95 civic EX (4-door with ABS). Is it only that strut bushing in the LCA that differs, or is the stabilizer bar mounting different also?
The struts share the same part# the on all the vehicles, but trailing arms and stabilizer bars do not. Here is what I found for the parts that mount into the LCA...
LCA Part# 52360-SH3-G21
matches '95 del sol and '95 civic EX (4-dr w/ ABS)
LCA Part# 52360-SH3-G31
matches '96-'97 del sol and '94-'01 Integra
Stabilizer bar part# 52300-SR3-901
matches the '95 del sol and the '95 civic
Stabilizer bar part#52300-SR3-A01
matches the '96 -'97 del sol and the Integra
Trailing Arm part# 52371-SR3-A80
matches the civic, the Integra and '95 del sol
Trailing Arm part# 52371-ST7-G61
Bosozoku11
Oct 16, 2010 08:15 AM
djnikko
Suspension & Brakes
Jun 2, 2009 06:09 AM
vancouverdc4
Suspension & Brakes
May 3, 2007 02:43 PM
RedlinedVTEC
Jan 1, 2005 06:17 PM
