wierd noise from distributor
hey so lately im getting like a chirping noise kind of from my distributor i think or from my injectors, its hard to tell without a stethoscope. what do you guys think it could be
Yes the dist can make chirping noise when the bearing starts going bad, when they are really bad they will SCREECH.
You might get some tubing to use as a "poor boy stethoscope" and listen right at the base of the dist where it attaches to the head.
Another common sign of the bearings going bad is a red metal dust inside the dist cap.
This is a problem that can leave you stranded, if let go too long.
