Injectors
Old Mar 6, 2007 | 09:49 AM
Booz's Avatar
Default Injectors
About to start working on an injector. Anything to know ahead of time? or helpful tips?
Old Mar 6, 2007 | 10:18 AM
mr.speaker's Avatar
Default Re: Injectors (Booz)
What are you doing?
Old Mar 6, 2007 | 01:33 PM
Booz's Avatar
Default Re: Injectors (honda89crxsi)
I think I need to replace one. I'm going to try and use one from a 90 crx si.
Old Mar 6, 2007 | 03:13 PM
mr.speaker's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Booz &raquo;</TD></TR><TR><TD CLASS="quote">I think I need to replace one. I'm going to try and use one from a 90 crx si.</TD></TR></TABLE>
OK,pull the ecu fuse and crank the motor untill the car dies,disconnect the battery negative,open the fuel tank door to releive pressure,have a lot of towels or rags handy because fuel will leak! Unclip the injector clips,be very carefull and use a tiny screwdriver,unbolt the fuel rail assembly fron the intake manifold,pull up and soak the leaking fuel with the rags,then pull the injector(s)..Also since you have this apart you might as well replace the o-ring.
be carefull where you put the fuel soaked rags.
Old Mar 6, 2007 | 05:56 PM
Booz's Avatar
Wow! thank you very much, this is exactly what I was wanting
kaspa35
Aug 18, 2008 11:50 AM
hondacrx2
Apr 23, 2007 06:13 PM
rexdout45
May 2, 2006 08:11 PM
Sinner
Jun 8, 2003 03:03 PM
INTEGRAMIKE
Dec 19, 2002 11:00 AM
