Usdm ITR cluster
I have a 1995 GSR and was looking to get a USDM ITR cluster and was wondering if the cluster was plug and play or some modification needed?
Thanks
Thanks
I believe its a direct plug and play. If anything, you might want to remove the green plastic film stuff on the back of your 95 cluster and put it on the itr cluster.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iH8RICERZ »</TD></TR><TR><TD CLASS="quote">I believe its a direct plug and play. If anything, you might want to remove the green plastic film stuff on the back of your 95 cluster and put it on the itr cluster.</TD></TR></TABLE>
If you do this method, his ABS light will go off.
OP: Check out my signature.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soundFX »</TD></TR><TR><TD CLASS="quote">pretty sure its direct plug and play</TD></TR></TABLE>
It's not if you want everything to work properly.
xtremeness101
Oct 30, 2004 05:19 PM
