Can i put a D16Z6 head on my 89 civic std????
Old Mar 6, 2007 | 08:29 AM
vtec25's Avatar
Default Can i put a D16Z6 head on my 89 civic std????
i heard i cant cuz supposably cuz of the shape of the pistons??
is this true or not?
Old Mar 6, 2007 | 09:51 AM
efking1985's Avatar
Default Re: Can i put a D16Z6 head on my 89 civic std???? (vtec25)
yea u can but have to change the computer to obd1
Old Mar 6, 2007 | 09:57 AM
MagnaniEG6's Avatar
Default Re: Can i put a D16Z6 head on my 89 civic std???? (efking1985)
dosent have to
Old Mar 6, 2007 | 09:59 AM
efking1985's Avatar
Default Re: Can i put a D16Z6 head on my 89 civic std???? (MagnaniEG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MagnaniEG6 &raquo;</TD></TR><TR><TD CLASS="quote">dosent have to</TD></TR></TABLE>
would run better
Old Mar 6, 2007 | 10:04 AM
WaCkOoOo69's Avatar
yah u should really change it it'll be better and a little faster
Old Mar 6, 2007 | 10:09 AM
mr.speaker's Avatar
Default Re: Can i put a D16Z6 head on my 89 civic std???? (WaCkOoOo69)
Yes the d16z6 head will bolt right on.
Best thing to do is convert to obd1 and use a p28 though,and also don't forget to take out the oil jet in the nonvtec block otherwise there will be no vtec.
another option is to stay with your current obd and run a chipped pm6 or other compatible ecu and have it setup for 1 wire vtec.
But whatever you do don't run the stock obd0 ecu and a switch to engage vtec,cause it would be pointless.
By the way this is called a mini-me do a search on google.
Old Mar 6, 2007 | 10:18 AM
MagnaniEG6's Avatar
Default Re: Can i put a D16Z6 head on my 89 civic std???? (honda89crxsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda89crxsi &raquo;</TD></TR><TR><TD CLASS="quote">Yes the d16z6 head will bolt right on.
By the way this is called a mini-me do a search on google.</TD></TR></TABLE>
its in the EF faqs
Old Mar 6, 2007 | 04:54 PM
vtec25's Avatar
ok kool. anybody know the compression ratio with this set up?
i dont find the d15b1 block or pistons in any compression ratio calculator.
Old Mar 8, 2007 | 02:01 AM
vtec25's Avatar
equ117
Aug 5, 2008 05:13 PM
littoboypinoy
16
Oct 26, 2006 04:19 PM
Xemu
31
Oct 19, 2006 06:16 AM
dmcclain
Jul 27, 2006 11:44 AM
