Searched' Cable b16?
Old Mar 6, 2007 | 01:29 AM
HTNoob's Avatar
B A N N E D
Default Searched' Cable b16?
How can I tell if its a an OBD0 b16 motor ?
Old Mar 6, 2007 | 08:28 AM
oodie's Avatar
Default Re: Searched' Cable b16? (HTNooB)
cream colored engine harness connector look for cable transmission and valve cover DOHC is bigger Than VTEC
Old Mar 6, 2007 | 08:38 AM
Lucky-13's Avatar
Default Re: Searched' Cable b16? (oodie)
or just look at your engine block by the header ports and youll see the year your b16 is from.
Or look at your ecu to see what obd you are.
Another sign is the valve cover and if your intake manifold.
Old Mar 6, 2007 | 10:26 AM
mr.speaker's Avatar
The only solid way is to check the date on the cylinder head,,and also there is a code on the block by the b16a stamp that will let you know if this engine came from an integra million series or civic/crx sir..
But as far as being wired for obd0 this poster above is right,the plugs on the motor will be a creamy white color..
sohcd16
Transmission & Drivetrain
Jul 20, 2009 05:23 PM
boblaw
Jan 29, 2008 04:52 PM
SIMSSEGA
19
Mar 31, 2006 09:24 PM
wizzards581
May 2, 2002 02:27 PM
