a couple RSX related q's
my girl has an 06 base RSX, and I recently picked up a 97 DB teg. I lovehow everything lights up red in hers so I purchased an OEM RSX stereo, will it work in my DB if I get an RSX or 02+ civic harness and splice into my harness? or is there some device that only allows it to function in 02+ vehicles?
Also, I called the local Acura Dealership (Tempe Acura) and asked for RSX instrument panel (cluster) bulbs... the guy was stumped, said he couldnt track down a part number or anything for them. I want my cluster to also light up RED!
The RSX cluster uses LEDs for illumination. You can do a red lit cluster modification by painting your bulbs.
You need a reverse harness for a 98+ Civic and splice it to your own. OR your can get the reverse harness and buy a radio harness (female plug) for your car, splice the two harnesses together and have it plug and play.
http://autolumination.com/74.htm here ya go. i was against painting bulbs myself i had an eh2 i used the 74 and 24 bulbs to do a white to amber swap. for the integra i dont kno what size tho sorry.
VTecCivic1505
Honda Civic (2001 - 2005)
24
Jan 29, 2007 02:31 AM
boomslang
12
May 18, 2005 08:29 AM
