westend alignment
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowassgsxr750 »</TD></TR><TR><TD CLASS="quote">does anyone know if there still around? i been trying to call for about a week now and nobodys picks up.i really need to get a alignment</TD></TR></TABLE>
I went there about 3 weeks ago. Doubt the shop has closed up since then, Darin didn't mention anything was amiss. If you wait long enough, you can get an answering machine.
There's a shop in Torrance that Darin used to work at and they use the same process, Johnson's Wheel Alignment Service. They charge a little bit more, but if you need one urgently and Darin isn't picking up, I'd recommend them.
I got my car aligned and corner balanced there because Darin couldn't do it for a week and was very impressed with their work. They work on a lot of track Porsche's.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jeff_B »</TD></TR><TR><TD CLASS="quote">There's a shop in Torrance that Darin used to work at and they use the same process, Johnson's Wheel Alignment Service. They charge a little bit more, but if you need one urgently and Darin isn't picking up, I'd recommend them.
I got my car aligned and corner balanced there because Darin couldn't do it for a week and was very impressed with their work. They work on a lot of track Porsche's.</TD></TR></TABLE>
how much is corner balancing run?
Johnson's charges $20 to check it and $48 if they have to align..... I've even seen them weight the driver's seat for accuracy.....they also have the scales handy in case you need extra attention in that area.....check it out......good luck
Jaydeep
Sep 15, 2004 11:56 AM
Fuster_Cluck
14
Dec 10, 2003 09:48 AM
