b18 cable trans w. linkage
Old Mar 5, 2007 | 05:55 PM
drumbum87's Avatar
Default B17A1 (Cable):YS1
Modified by drumbum87 at 9:47 AM 3/8/2007
Modified by drumbum87 at 9:50 AM 3/8/2007
Modified by drumbum87 at 9:52 AM 3/8/2007
Old Mar 8, 2007 | 08:49 AM
drumbum87's Avatar
Default fs;B17A1 (Cable):YS1
B17A1 (Cable):YS1
This transmission is found on the rare "blacksheep" of b-series motors. The most important feature here is that its cable-type. This means you can bolt this into any 93 and older integra and 91 and older civic without having to change to hydraulic. The synchro's on this transmission are still considered weak, however the gearing is very good for all motor applications as its identical to the B16A transmissions. Finally, this transmission did not have factory LSD, so keep that in mind when someone is trying to tell you otherwise. Although its going to be difficult to find and usually when you do, there is something wrong with it. FOR EXAMPLE THIS ONE HAS BAD SYNCROS!!!
BEST OFFER!!!!
or trade for EK parts!!!
PURPLETERROR aka BIGMATT
May 15, 2007 09:07 AM
john breezy
Jun 12, 2006 04:16 PM
