Weld Racing Wheels, backspacing? clearance?
Old Mar 5, 2007 | 05:06 PM
ilovejdm's Avatar
Default Weld Racing Wheels, backspacing? clearance?
I'm ordering a set of Weld Racing wheels 13x8 to put some slicks on. I'm ordering them from http://www.exospeed.com and I was wondering what the proper backspacing would be for my car and will I need extended wheel studs? My car is a 1993 del sol. Thanks.
Old Mar 5, 2007 | 05:34 PM
ExospeedAMcrx's Avatar
Default Re: Weld Racing Wheels, backspacing? clearance? (ilovejdm)
what size slicks are you planning to use. You can choose the certain backspace to bring out the rim farther out or bring it in. sometimes you want the wheel farther out to clear those wider slicks. the backspace is the length from the inner edge of the wheel to the mounting surface on the back of the rim.
and as far as extended wheel studs, yes you do need them for the Weld Import Magnums and actually all race tracks will require you to have them with these type of wheels.
Old Mar 5, 2007 | 06:57 PM
ilovejdm's Avatar
Default Re: Weld Racing Wheels, backspacing? clearance? (exospeedAMcrx)
oo, well mainly I wanted to check to see if I was going to need to get extended wheel studs or not, Since I do I'm just going to go with a set of lenzos and I'm not sure what size slick im going to go with yet, I'm sure exospeed will tell me wen I call and order them. Thanks.
Old Mar 5, 2007 | 06:59 PM
crx2nr822's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ilovejdm &raquo;</TD></TR><TR><TD CLASS="quote"> I'm sure exospeed will tell me wen I call and order them. Thanks.</TD></TR></TABLE>
You did notice his sn with the exospeed part right? You can ask him right here, because he is pretty much gonna be the one sending them to you, LOL.
Old Mar 5, 2007 | 07:13 PM
Default Re: Weld Racing Wheels, backspacing? clearance? (crx2nr822)
hehe. well PM, call, email or ask here. I'll let you know your options.
Old Mar 5, 2007 | 07:21 PM
fast is fun's Avatar
5 " back, if you use 24.5 /13 mt.
dunkd
Jun 6, 2005 12:01 PM
95c1v1cs1
Sep 11, 2003 04:32 PM
DLB1994
Nov 25, 2002 04:13 AM
acuraLSSE95
Aug 6, 2002 10:56 PM
ILOVEGIRLS
Apr 10, 2002 05:17 AM
