hesistation rough idle
Old Mar 5, 2007 | 04:26 PM
articsilber323's Avatar
Default hesistation rough idle
i have a 1988 crx with a d15 in it that i picked up for 200 bucks
it has been sitting for a while and im trying to get it running decent
i have drained all the old gas out and changed the oil 2 times along with tranny fluid
i have also changed out plugs
my problem is that it has a rough idle and hesitates very badly
any time i try to get it gas more then 1/6 throttle it dosent want to do anything and seams like it wants to stall
only thing i can think of is that it dosent have any back preasure
can this cause this problem?
it is currently open header
any input would be awsome
thanks
Old Mar 5, 2007 | 04:34 PM
let me also add that sometimes it revs fine with no hesistation
Old Mar 5, 2007 | 06:10 PM
anyone?
Old Mar 5, 2007 | 07:31 PM
no 1
Old Mar 5, 2007 | 08:40 PM
jetoutant's Avatar
Default Re: (articsilber323)
what codes are you getting from the ECU
Old Mar 6, 2007 | 04:30 AM
the ecu isnt throwing any codes
Old Mar 6, 2007 | 08:42 AM
wiZCo's Avatar
Stouts 'n' Scotch
Try changing the fuel filter, spark plug wires and distributor rotor, make sure timing is on and run some seafoam through it. Then you can complete the tuneup and go from there.
Edit: just saw you're running open header . Not having an O2 sensor will make your idle all screwed up. You may want to remedy that.
Old Mar 6, 2007 | 10:11 AM
the car only has 1 o2 sensor and i have that installed
Old Mar 6, 2007 | 10:32 AM
jetoutant's Avatar
check the screw that hold the rotor in place it might have came loose or fell off and your rotor is just arcing all over inside
Old Mar 6, 2007 | 10:34 AM
wiZCo's Avatar
Stouts 'n' Scotch
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by articsilber323 &raquo;</TD></TR><TR><TD CLASS="quote">the car only has 1 o2 sensor and i have that installed</TD></TR></TABLE>
Ahhh, my fault I was thinking you were saying no header instead of open header.
I still say you give her a nice tuneup and see where you stand after that.
Old Mar 6, 2007 | 05:16 PM
the little butterfly valve before the throttle body seams like it doent open very much when you give it gas
could that be a problem
the car idels fine but sometimes like 50% it does this hesistation problem
it also pops when u try to give it gas and it dosnt rev and u let off of the gas it pops
also i have had it where you cant rev past 3k and 4k and 5k
Old Mar 7, 2007 | 04:33 AM
bump
Old Mar 18, 2007 | 07:45 PM
ef_zcvtec's Avatar
clean out the throttle body with a spray and adjust your tps..
ftrms
Apr 14, 2010 05:58 PM
Mik3
Feb 5, 2006 06:55 PM
Vera
Jan 12, 2006 02:41 PM
dmxsoulja3
12
Nov 16, 2005 12:10 PM
jpelle
Mar 15, 2002 12:46 PM
