Broken Turn Signal/Lights Lever..
Old Mar 5, 2007 | 03:31 PM
Meatwad1355's Avatar
Default Broken Turn Signal/Lights Lever..
I broke my handle off of my 91 civic sedan.. The whole plastic lever got hit off, it was already broken i couldnt turn the brights on and stay on( i would have to hold it torwards myself) now the whole lever snapped off...
Where can i buy a new 1/used 1? and how would i replace it???
I tried unscrewing the Two bolts from the underbelly of the steering column, then the plastic wouldnt come apart... but thats no problem for now, but tomarrow i will have to drive home at night from work so with no light im kinda screwed...
Ty for help, i might post up pix in a few.. maybe..
Old Mar 5, 2007 | 04:10 PM
mahatma's Avatar
Default Re: Broken Turn Signal/Lights Lever.. (Meatwad1355)
you've got to take the steering wheel off....then there's a snap ring right behind it that holds the upper & lower column plastics together
then it's just a couple screws and electrical plugs, you should have no problems.....
also, you can use any 88-91 stalk to replace it. i put one from my '89 crx onto my '91 sedan. i'm thinking about rigging the rear wiper control to do something....
Old Mar 5, 2007 | 04:15 PM
dr_latino999's Avatar
Default Re: Broken Turn Signal/Lights Lever.. (mahatma)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mahatma &raquo;</TD></TR><TR><TD CLASS="quote">
also, you can use any 88-91 stalk to replace it. i put one from my '89 crx onto my '91 sedan. i'm thinking about rigging the rear wiper control to do something....</TD></TR></TABLE> You can use any one to replace it, but there are SOME differences. There was a brief discussion in this thread if you want to get technical about it - https://honda-tech.com/zerothread?id=1862769
Also, OP you have a PM.
Old Mar 5, 2007 | 08:50 PM
Where would i buy these parts, and what is the technical term im lookin for?
Ty for help
Old Mar 5, 2007 | 08:52 PM
EL Vap133's Avatar
Local junkyard (try the Tolleson AZ area), Marketplace here on HT, ebay, http://www.car-part.com
Old Mar 7, 2007 | 03:19 PM
Default Re: Broken Turn Signal/Lights Lever.. (EL Vap133)
I got the part, and it looks like it needs to be slid onto the wheel, so i took off my steering wheel, and theres a big bolt in the way ( no snap rings, maybe they come after the bolt )
If i remove that bolt, how will i re center my wheel? anything i need to kno so i dont screw myself???
Ty for info reply asap, its gettin dark
tylergwesterhold
May 9, 2009 05:07 PM
excivicboy96
10
Mar 21, 2007 02:48 PM
kevinoneill
19
Aug 14, 2006 08:10 PM
trinispeed
Apr 8, 2002 09:32 PM
