What is your swaybar setup?
Old Mar 5, 2007 | 03:16 PM
Coolcat55's Avatar
Default What is your swaybar setup?
Just wondering, what bar do you use on front and rear? if you have the stock setup (19mm front, nothing in back) plz don't bother posting, thank you. I have a Si rear bar coming (15mm) and i'm wondering if i should take off the front one or keep it on when i get the rear one.
Old Mar 5, 2007 | 03:17 PM
Tyson's Avatar
Default Re: What is your swaybar setup? (Coolcat55)
unless you have a 4dr sedan, or HF crx, your front swaybar is 18mm.
swaybars are to be considered with the whole suspension package. kind of useless to just say what swaybar you use.
Old Mar 5, 2007 | 03:36 PM
Coolcat55's Avatar
Default Re: What is your swaybar setup? (Tyson)
i have a 4dr. look at sig.
yes, i know sway bars are only part of the whole suspension, still, i just want an answer to the question, if it helps i have cheapo coilovers that will be put on when they arrive (please hold the ranting about how shitty they are, i've already heard it)
Old Mar 5, 2007 | 04:18 PM
QuarterMileMaster's Avatar
I have a hatch but I've got a ST 22mm Rear Sway bar and no front.
Old Mar 6, 2007 | 03:18 PM
Coolcat55's Avatar
Default Re: What is your swaybar setup? (QuarterMileMaster)
do you autox it? how does it handle, is it much more oversteer oriented?
Old Mar 6, 2007 | 03:41 PM
fiddynut's Avatar
S/T front and rear. Love it. Best suspension upgrade I have made.
Old Mar 6, 2007 | 03:56 PM
dwerpk's Avatar
does that rear st bar clear the exhuast better then the stock crx si one becuase my car has a skunk2 exhuast and the stock bar hits my exhuast
Old Mar 6, 2007 | 04:38 PM
fiddynut's Avatar
It clears my Greddy.
Old Mar 6, 2007 | 04:43 PM
Coolcat55's Avatar
how much was it for the s/t one? wat are the widths?
Old Mar 6, 2007 | 04:56 PM
fiddynut's Avatar
Default Re: (Coolcat55)
Summit has the best prices I have seen. And the width I have no clue.
Old Mar 6, 2007 | 05:05 PM
Coolcat55's Avatar
Default Re: (fiddynut)
yeah summit does have a pretty good price. 7/8" pretty damn chubby.
wat do yall think about my Si bar on back, and nothing on front (on a 4dr if that matters)?
Old Mar 6, 2007 | 05:31 PM
The guy that had it before me auto x'd the crap out of it. It is more oversteer oriented which is the way I like it.
As for clearance, I'm turbo and have 3" exhaust all the way back and it clears fine.
Old Mar 6, 2007 | 06:34 PM
tpod's Avatar
hf on the front and St bar on a back is a killer set up. i have also been told just to run ST back sway bar and no front. i will test which i like better this summer
Old Mar 6, 2007 | 07:33 PM
Scotland:EF3's Avatar
awesome got anymore pics?? what lca's are those?? any what year is that?
Old Mar 6, 2007 | 09:13 PM
fiddynut's Avatar
Default Re: (ProJect:EF9)
Car is a 90 CRX, LCAs are Function&Form, And sorry no mpre pics.
Old Mar 7, 2007 | 07:59 AM
The Hooligan's Avatar
From: spinning DnB till your head explodes,jersey/philly
im running an hf front with st rear on a crx. still wondering if i should try the front st bar, i was told my current setup is better.
Old Mar 7, 2007 | 08:23 AM
Bevenue's Avatar
whats everybodies opinion about DA sways... ls 24 or 25 i think, and 16 rear... on a crx? Any pos/negs on this? I noticed everybody is goin larger in the rear and smaller in the front, is this setup gonna exagerate the understeer? I'm using it as a daily driver and a weekend toy so its not gonna go thru any serious cornering.
Thanks,
~Chris
Old Mar 7, 2007 | 08:40 AM
HBK's Avatar
HBK
Default Re: (Bevenue)
I went to the junkyard and got a 16mm rear DA sedan sway bar and it didn't fit It was about an inch and a half too short. So I'm running a rear CRX Si sway on my crx and soon to have a hf front sway.
Old Mar 7, 2007 | 08:41 AM
Boosted Chemist's Avatar
Default Re: (dwerpk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dwerpk &raquo;</TD></TR><TR><TD CLASS="quote">does that rear st bar clear the exhuast better then the stock crx si one becuase my car has a skunk2 exhuast and the stock bar hits my exhuast</TD></TR></TABLE>
The st clears my thermal 3"
Old Mar 7, 2007 | 09:28 AM
Bevenue's Avatar
i have the da's on my crx at the moment but i have yet to drive it. I'm in the process of building a motor for it.
Old Mar 7, 2007 | 10:08 AM
HT Chaplain's Avatar
Loved
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fiddynut &raquo;</TD></TR><TR><TD CLASS="quote">S/T front and rear. Love it. Best suspension upgrade I have made.
how much weight does the rear ST bar add?
Old Mar 7, 2007 | 02:16 PM
Default Re: (HT Chaplain)
with all the brackets,hardware and bar about 10-15 lbs.
Old Mar 7, 2007 | 06:46 PM
fiddynut's Avatar
Not enough to mater.
Old Mar 19, 2007 | 12:20 PM
anyone selling a ST for an ef rear??
Old Mar 30, 2007 | 05:44 PM
bumpo
specialized108
56
Jan 25, 2009 02:27 PM
envee
Suspension & Brakes
Apr 17, 2007 09:26 PM
Nothing.Special
Suspension & Brakes
May 17, 2005 05:46 PM
oneslodx
13
Aug 20, 2004 01:07 PM
Archidictus
Jul 21, 2003 02:35 PM
