obdo dizzy for b16??????????????
are u serious an ls dizzy will work on a B16 swap someone told me it had to be and obdo B16 dizzy. can anyone confirm this because i need a dizzy for and obd0 B16 swap.
Yes the 90 integra one will work but you will have to cut off one leg and it will only be held on with 2 bolts. The stock si one will work too with a leg cut off but it only lets you get 14 degrees(stock is 16) of timing so it will run a little off but if you are stuck it works.
