EBAY GROUND WIRES!
I bought it.. BUT now i'm not sure how to install it and don't really know how well it will work. Anybody use these? I visited other forums and some people say it works but others say it does no good.. Kind of mixed feelings on it.. I need to ground it correctly and see how it works! The reason I got it is because the engine shakes a lot when I idle long and when the headlights are on.. Also one headlight is brighter then the other! What's the deal?! I replaced the bulbs to JDM yellow ones and it still does it!
Well my old factory ground wire does look a little nasty so it's good i'm replacing it.
http://cgi.ebay.com/ebaymotors...ZWDVW
Well my old factory ground wire does look a little nasty so it's good i'm replacing it.http://cgi.ebay.com/ebaymotors...ZWDVW
I acually already bought it.. I know it's a fake HKS ground kit but I just need better grounding.. I just need to know how to install it at this point! Damn ebay doesn't give me any intructions with it!
it looks like you just mount that main ground blck to the frame somewhere and then run all the wires to were you have anthing that needs a ground. but idk.
I don't really see a problem with ebay ground kits. I mean wires are wires, nothing more. And on our old *** cars, the grounds are usually all fucked up anyway.
There is a metal plate with a battery connecter on the bottom.. I don't know if the connecter should go on negative or positive on the battery.. There are so many wires too! don't know where they all go
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmDRIFTER »</TD></TR><TR><TD CLASS="quote"> I don't know if the connecter should go on negative or positive on the battery..
Battery connector goes on the negative terminal
</TD></TR></TABLE>Battery connector goes on the negative terminal
