removing rear seat
im needing to swap out my back seats lookin at them i dont see any visual bolts or anything how do you go about taking the back seat out...my only guess is i have to take off the side plastics in the back.
theres a bolt in the middle of the back seat, towards the back and the rest has hooks holding it down. the back rest pivots on 2 points where they are connected, i remember you have to push the passenger seat towards the passenger side and remove a plastic spacer insert, once its out just pull the seat up a little and slide the other side out.
hope that get you started
move the rear seat sections(the vertical part) towards the middle of the car one at a time. at the same time put your hands down in between the seat and side plastic where the vertical setion pivots. there is a small black plastic clip on the shaft that the seat pivots on. remove th clip, then slide the seat towards the outside of the car. now pull up on it on the inside edge, it may be a little difficult but it will come out. repeat it for the other piece. now with those out of the way you should see the one bolt that holds the bottom piece on.
let me know if this helped
sunsetway
Sep 19, 2005 02:05 PM
Powered By Garrett
Mar 26, 2005 08:29 PM
