EACV rebuild question
Old Mar 5, 2007 | 09:58 AM
B16CRXT's Avatar
Default EACV rebuild question
Can anyone tell me how to remove this screw? It seems to hold the center section together. it is 5 sided whereas an allen key is 6. I dont have naything that can remove this. Is this a special tool that I cant get my hands on?
TIA
Modified by B16CRXT at 6:12 AM 3/6/2007
Old Mar 5, 2007 | 10:50 AM
FalkenSiR's Avatar
Default Re: EACV rebuild question (B16CRXT)
ive hear people just get new ones if cleaning them does nothing... check at honda
Old Mar 5, 2007 | 11:01 AM
B16CRXT's Avatar
Default Re: EACV rebuild question (FalkenSiR)
yea, they are like $300.
Old Mar 5, 2007 | 07:48 PM
PrettyLude's Avatar
its just a allen bit screw
Old Mar 6, 2007 | 02:11 AM
B16CRXT's Avatar
Default Re: (PrettyLude)
Look at it closer. It's not an allen. Allen is 6 sided. This is 5. Someone said something to me about a pentagon wrench...I'm gonna be on the lookout for those...
Old Mar 6, 2007 | 05:18 PM
PrettyLude's Avatar
stick a torx bit in there, its gonna work
Old Mar 6, 2007 | 06:47 PM
B16CRXT's Avatar
Hell yea. That did the trick. A T25 Torx screwdriver got it out. wasnt a 'perfect' fit but it got it out. Thanks bro.
Old Mar 9, 2007 | 10:00 AM
Sahwn's Avatar
keep us posted on what you are doing.
I have cleaned mine 2 times and now the Check Engine light is on.
I want to know how to fix the damn thing too or I will just get a used one.
Old Mar 9, 2007 | 12:27 PM
cueballsi's Avatar
Default Re: (Workless)
ONLY CLEAN WITH CARB SPRAY!!!!!!! DO NOT USE BRAKE CLEAN!!!!!! Break clean will destroy any diaphram material
Old Mar 10, 2007 | 08:58 PM
B16CRXT's Avatar
Default Re: (cueballsi)
yep, all I have ever used on them is carb cleaner. Still doesn't solve the issue. I think maybe the spring inside is weakened. I tightened that funny screw some after I took the spring out and cleaned in there really well. I'll install this iacv soon and hopefully fix the problem...Don't waste your money on a used one. I did, twice...
siVix
Aug 11, 2009 10:30 PM
Hanmin
Mar 22, 2008 12:29 PM
oprac
Aug 17, 2007 10:32 AM
escape2me
Apr 15, 2005 10:31 PM
jcool5
11
Oct 14, 2004 10:29 AM
