p13 Barometric sensor
Old Mar 5, 2007 | 08:25 AM
Grandhustleman86's Avatar
Default p13 Barometric sensor
My buddy has a p13 and is throwing a code 14....barometric sensor error or something like that....the question is where is the barometric pressure sensor on the ecu....and also can the barometric sensor be replaced....
and also which sensor is the CPS sensor on the 93' H22a dizzy....and can it be replaced?
Old Mar 5, 2007 | 09:31 AM
notoriousB's Avatar
Default Re: p13 Barometric sensor (Grandhustleman86)
the baro pressure sensor is inside the ECU. it can not be replaced.
is he running the AFC hack or emanage + bigger injectors by chance? if so the baro pressure CEL is normal.
Old Mar 5, 2007 | 03:19 PM
Default Re: p13 Barometric sensor (notoriousB)
actually the ECU is chipped but we do not kno with what map and program....it runs real rich when started then leans out (to normal) when warned up....
Old Mar 6, 2007 | 04:34 AM
notoriousB's Avatar
sounds like it's time to find a tuner.
roy ezechukwu
Feb 6, 2014 02:13 PM
sh!ft
May 13, 2009 01:18 PM
sharky8513
12
Feb 5, 2005 08:25 AM
Civic89
Jun 17, 2002 01:26 PM
Cm91h22a
Apr 16, 2002 12:38 AM
