CNC VIDEO OF TUBO HOUSING
Old Mar 5, 2007 | 08:22 AM
EGJDM's Avatar
Default CNC VIDEO OF TUBO HOUSING
Here is a nice high speed machining video of some turbo housings being finish machined. Some of you may find this interesting, I sell this equipment everyday and get really interested in how the industry progresses to be more efficent.
http://www.youtube.com/watch?v=fl4tK9Q2PCM
Modified by EGJDM at 9:50 AM 3/5/2007
Old Mar 5, 2007 | 09:10 AM
locash's Avatar
Default Re: CNC VIDEO OF TUBO HOUSING (EGJDM)
Wow. Makes my new Haas VF2 look lame.
Old Mar 5, 2007 | 10:49 AM
EGJDM's Avatar
Default Re: CNC VIDEO OF TUBO HOUSING (locash)
The haas' sure are a popular machine. How do you like yours? They seem to make it really attractive with there easy financing. Sometimes it is as if they will give anyone with a pulse one. Because if you don't make the payment and you go to call in for the code to unlock the controller that month you are out of luck. I can say this the are great machines to sell tooling because they go through it like mad.
Old Mar 5, 2007 | 11:02 AM
tony1's Avatar
That's bad ***! What does a machine like that cost?
Old Mar 5, 2007 | 11:19 AM
levelzero's Avatar
*drools* wow that thing kicks the crap out of my little milling machine
Old Mar 5, 2007 | 12:12 PM
EGJDM's Avatar
Default Re: (levelzero)
that machine there would easily be 1 mill+.
Old Mar 5, 2007 | 12:29 PM
tony1's Avatar
Default Re: (EGJDM)
Dang...
Old Mar 5, 2007 | 12:32 PM
Synapse Motorsport's Avatar
Default Re: (tony1)
Wow, simply amazing.
Old Mar 5, 2007 | 03:24 PM
180MPHGUY's Avatar
They had one of those machines set up at the IMTS show last fall. It was bad *** to watch run.
Old Mar 5, 2007 | 05:11 PM
kordenbrock motorsports's Avatar
Wow!
Old Mar 5, 2007 | 05:30 PM
93supercoupe's Avatar
Default Re: (kordenbrock motorsports)
Old Mar 5, 2007 | 06:24 PM
Enzo-Racing's Avatar
Default Re: (93supercoupe)
That **** is gangster...
Old Mar 5, 2007 | 07:25 PM
Niles's Avatar
If it can't make me a CNC margarita I'm not interested!
Just kidding, that was neat, thanks.
Old Mar 5, 2007 | 07:28 PM
EF8IGHT's Avatar
Default Re: (Enzo-Racing)
i can do that with my dremel
Old Mar 5, 2007 | 10:41 PM
99_GS-T's Avatar
Awesome. I watched a few other Stama videos too. Some very cool technology.
It is interesting that the machines seem to rely on very little coolant. One of my professors is currently doing a lot of research on tool coatings for high speed machining for this very purpose. Interesting to see how different companies approach the matter in different ways. It seems most will flood the part with coolant to maintain stable part sizing and finishes.
Old Mar 6, 2007 | 11:52 AM
EGJDM's Avatar
Default Re: (99_GS-T)
really if you talk to a lot of guys they will prefer to cut dry if possible and may use compressed air. One of the main functions of the coolant is to evacuate the chips so you are not recutting them damaging your cutter. A lot of carbide tooling thrives on the heat and coatings have came a long way. Seems as though most of the coatings are engineered to function in certain situations.
Old Mar 6, 2007 | 09:36 PM
Rosko's Avatar
Default Re: (EGJDM)
holy ***** thats cool.
Old Mar 7, 2007 | 08:53 AM
Agtronic's Avatar
That is insanely cool!
Old Mar 7, 2007 | 10:21 AM
HT Chaplain's Avatar
Loved
Default Re: CNC VIDEO OF TUBO HOUSING (Agtronic)
Old Mar 7, 2007 | 02:01 PM
thermal's Avatar
Default Re: CNC VIDEO OF TUBO HOUSING (HT Chaplain)
I have one in my garage......
Old Mar 7, 2007 | 08:48 PM
dave@passenger's Avatar
Dang and I thought my old ***** manual mill was cool.
Old Mar 7, 2007 | 08:49 PM
dohcdelsol's Avatar
Default Re: CNC VIDEO OF TUBO HOUSING (thermal)
and to think, thats the type of **** my grandpa would make each and everyday. something like that would take him all day just to turn 1 turbine housing.
RIP grandpa cause i know ur rollin over in ur grave now. love you.
Old Mar 7, 2007 | 09:49 PM
rlockwood's Avatar
Default Re: (EGJDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGJDM &raquo;</TD></TR><TR><TD CLASS="quote">really if you talk to a lot of guys they will prefer to cut dry if possible and may use compressed air. One of the main functions of the coolant is to evacuate the chips so you are not recutting them damaging your cutter. A lot of carbide tooling thrives on the heat and coatings have came a long way. Seems as though most of the coatings are engineered to function in certain situations.</TD></TR></TABLE>
hate to state the obvious here, especially when I know full well that some tooling can see see HUGE advantages from dry cutting, its simply easier to view when cutting dry.
Old Mar 8, 2007 | 05:36 AM
kranked91dx's Avatar
That is one bad *** CNC... damn, two part's at a time, I never saw that befor this vid, although, I know machining pretty well. it's damn FAST...
thank's for sharing,
JP
Old Mar 18, 2007 | 11:16 AM
pizzle's Avatar
Default Re: CNC VIDEO OF TUBO HOUSING (kranked91dx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rlockwood &raquo;</TD></TR><TR><TD CLASS="quote">
hate to state the obvious here, especially when I know full well that some tooling can see see HUGE advantages from dry cutting, its simply easier to view when cutting dry.</TD></TR></TABLE>
Where I work...
When it comes to production CNC machining, the view of the part is good to have, but not critical. Typically, once the first part is set-up and ran, it is inspected. If it passes inspection, then it's lock and load from there. All parts that come out of the machine are then inspected by the machine operator w/ check gauges/measuring tools w/ the exception of 1 out of every 5 being checked by Q.C. (quality control).
To check in on the part while it's in the process of being machined, there is a button called single-block which allows you to watch it machine step by step.
There is alot to take into consideration when dry-cutting...too much to get into.
Modified by pizzle at 11:39 PM 3/22/2007
