Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Heavy Duty clutch needed for DE events???
Old Mar 4, 2007 | 08:42 PM
vbspec's Avatar
Default Heavy Duty clutch needed for DE events???
Hey guys. I'm kicking the idea around of changing my flywheel and clutch on my 96 RS. The car is low on the hp side @ 125-130 WHP if I'm lucky. I figure a lighter flywheel will help alot... like it did on our CSP CRX. And if I'm going to change the flywheel I might as well change the clutch while I'm in there. The car will be run with street tires for another year and I'm asking the wife for NT01's or RA1's for Christmas 07.
I guess my choices are:
OEM type?
EXEDY, CM or others "Stage 1"?
Or others?
I just don't want to get the OEM replacement if its good enough for now and need a stronger on when I change tires or add a diff to the car (meaning within the next year)
Thanx for any insite!
Old Mar 5, 2007 | 08:30 AM
Lo-Buck EF's Avatar
unless your planning on putting boost on the car, an oe replacement or other full face clutch will work just fine.
Old Mar 5, 2007 | 09:01 AM
vbspec's Avatar
Default Re: (Lo-Buck EF)
Thank you sir!!
That was my thought but I just wanted to make sure I didn'r miss something!!!
Old Mar 5, 2007 | 02:24 PM
Lo-Buck EF's Avatar
no prob. im using a stage 1 exedy on my b-series EF and its been problem free. i recommend exedy on the ef chassis because the pressure plate isn't super stiff. i had an act in my single cam and the pedal pressure was excessife and i broke clutch cables and pedal assemblies.
Old Mar 5, 2007 | 03:27 PM
Civic44's Avatar
I installed an OEM Type R clutch in my RS tranny with a light flywheel and it's worked great. My race car has about 200 crank hp.
Old Mar 5, 2007 | 07:09 PM
vbspec's Avatar
Default Re: (Civic44)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civic44 &raquo;</TD></TR><TR><TD CLASS="quote">I installed an OEM Type R clutch in my RS tranny with a light flywheel and it's worked great. My race car has about 200 crank hp.</TD></TR></TABLE>
Did you use the Type R pressure plate, or the RS? I was looking on line and can find part #'s for the TypeR and GSR clutch and pressure plates, but not the LS/RS. Does anyone have any ideas???
Modified by vbspec at 6:54 PM 3/6/2007
Old Mar 6, 2007 | 02:08 PM
Lo-Buck EF's Avatar
Default Re: (vbspec)
correct me if i'm wrong but arent all the hydro b-series clutches interchangable?
Old Mar 7, 2007 | 03:56 AM
vbspec's Avatar
Yeah they are but my question was and I guess you kinda anwsered it... Are the GSR and Integra pressure plates different form the LS/RS? I guess not.
Old Mar 7, 2007 | 06:27 AM
Todd Reid's Avatar
three years on my used, stock, junkyard oem clutch assy. it still feels perfect.
its in my H1 K20 racecar.
for road racing, you don't need more than the stock oem clutch, unless you are abusive.
todd
Old Mar 7, 2007 | 02:06 PM
Lo-Buck EF's Avatar
Default Re: (Todd Reid)
if you havent purchased one yet, pm BlueR (mark) he's an exedy dealer, probably has what your looking for in stock and has good prices
Old Mar 8, 2007 | 03:28 PM
Civic44's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vbspec &raquo;</TD></TR><TR><TD CLASS="quote">
I used the ITR pressure plate.
kornerk12
Nov 5, 2006 07:05 AM
xintegr
Mar 26, 2006 06:25 PM
cbr1
16
May 17, 2005 07:43 AM
5thGenBen
Jun 26, 2004 11:28 AM
DsITR
Jan 4, 2003 11:25 AM
