W16 Engine Block Machined From Solid Billet
Umm what scale was that motor. It was hard to tell if it was full size or one of those mini motors. Nice video though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toyomatt84 »</TD></TR><TR><TD CLASS="quote">I couldn't imagine how much one of those blocks would cost. Is it just me, or did the adjoining cylinder walls look rather thin?</TD></TR></TABLE>
Thats what i thought they looked super thin. Wish i could of seen the head
Its an aluminum block so it is going to recieve some type of cylinder liner/sleeve.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boner_Ben »</TD></TR><TR><TD CLASS="quote">
Its an aluminum block so it is going to recieve some type of cylinder liner/sleeve.</TD></TR></TABLE>
Didn't know it was aluminum.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HT Chaplain »</TD></TR><TR><TD CLASS="quote">So whats a W16? whats it in??</TD></TR></TABLE>
i think vw designed it. but not positave. there could be more than one company in the design now.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HT Chaplain »</TD></TR><TR><TD CLASS="quote">So whats a W16? whats it in??</TD></TR></TABLE>ITS the bugatti veyron its a w16 quad turbo that does 253mph.it made like 1001hp an 926ft lbs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by swapit »</TD></TR><TR><TD CLASS="quote">ITS the bugatti veyron its a w16 quad turbo that does 253mph.it made like 1001hp an 926ft lbs.</TD></TR></TABLE>
are you sure? i know thats whats the Bugatti has but i thought the Bugatti had twin vr8 motors mounted at 90* with a custom crank. But then again it could have just be vr8 architecture, i'm not really sure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soccerking3000 »</TD></TR><TR><TD CLASS="quote">
yes its a bugatti engine.. The W8 is in the VW passats
</TD></TR></TABLE>yes its a bugatti engine.. The W8 is in the VW passats
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quickgti1.8t »</TD></TR><TR><TD CLASS="quote">
yes its a bugatti engine.. The W8 is in the VW passats</TD></TR></TABLE>
the vw's arent w8's they are a low profile v8
the vw's arent w8's they are a low profile v8</TD></TR></TABLE>
A W8 engine is a Volkswagen eight cylinder piston engine in a W configuration, or two juxtaposed 15 degree V4 engine blocks, mounted at 72 degrees to one another and coupled to one crankshaft
That was interesting to watch.
Never knew how a w16 was configured.
It's like two vr6 engines combined into a w12. Except the vr6 would have to be a vr8. I guess so it would be 16....
Honda should try something like that with the k/f series.
8000rpm 5.0 dohc vtec v8.
Then mimic bmw's m-coupe. Turn the s2k into a hard top. Call it the s-coupe.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost »</TD></TR><TR><TD CLASS="quote">i would like to nominate this motor for being the biggest clusterfuck on an egineering nightmare and a machinst's death</TD></TR></TABLE>
Have you seen a cut-away of an old single prop airplane engine? There are parts and pistons moving in every direction. Nuckin' Futs!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hondatec38 »</TD></TR><TR><TD CLASS="quote">Have you seen a cut-away of an old single prop airplane engine? There are parts and pistons moving in every direction. Nuckin' Futs!</TD></TR></TABLE>
you're talking about a radial motor. yeah so much for the simplest idea winning.
