Main bearing ?'s for ZC
Old Mar 4, 2007 | 04:44 PM
GTibunny16v's Avatar
Default Main bearing ?'s for ZC
Im currently rebuilding a ZC engine for my friend. Removed the main bearings and 4 of them have a brown/red color, it could be even orange and the middle bearing is clearly green.
My question is, what bearings do I use? Can I use the D16a1 bearings? Also, how can I tell whats the exact color of the brownish ones are? I cant find any info on this damn motor. If anyone has a link where I can get a Helms manual for this thing, Id owe you a cold one. Or if you could give me the specs on the bearings.
Old Mar 4, 2007 | 05:03 PM
IP RACING's Avatar
Default Re: Main bearing ?'s for ZC (GTibunny16v)
im not 100% sure but if its a sohc zc then use an a6 main bearing if its a dual overhead cam I would say use a a1 main bearing
Old Mar 4, 2007 | 06:41 PM
Default Re: Main bearing ?'s for ZC (IP RACING)
Yeah, its a 92 DOHC Integra engine as far as I know.
Old Mar 4, 2007 | 07:04 PM
Bevenue's Avatar
92 dohc integra would be a b18a... if its a zc dohc, it uses d-series bearings. you can use a6 or a1 bearings they both will work.
Old Mar 4, 2007 | 11:58 PM
Default Re: (Bevenue)
I was told it was from a 92 and that the lesser model Integra's in Japan kept the ZC till 92. Ehh...whatever year it came from. I guess Ill have to go with the a1 bearings, thanks guys.
zenon8890
Jan 6, 2010 07:44 AM
DoHcZC91si
Feb 23, 2007 08:34 AM
Rob_hoody
Apr 30, 2002 06:18 PM
Grumpy
Sep 10, 2001 03:49 PM
