JDM fuse box layout
Old May 22, 2002 | 04:14 AM
Mr. Flibble's Avatar
Default JDM fuse box layout
Hi. I have a JDM 4th gen prelude and one if the fuses keeps blowing. Thing is that, along with everything else on the car, the fuse box markings are in japenese. Is there anywhere on the web that will tell me which fuse is which?
Old May 22, 2002 | 05:46 AM
Meccanoman's Avatar
Default Re: JDM fuse box layout (Mr. Flibble)
Hello again mr flibble
Fancy meeting you here!!
Which fuse is blowing. I got my hands on the Maintainence repair and construction, Shop manual few weeks ago. Should be able to help.
Cheers
Mek
Old May 22, 2002 | 12:54 PM
Default Re: JDM fuse box layout (Meccanoman)
What a coinsidense! Still haven't got any money together for nitrous!
I've uploaded a pic of the fusebox cover and circiled the one that blows. - My fan isn't working either and the car is ovrheating too (maybe thats the fuse thats going?)
The pic is here: http://www.esatclear.ie/~flibble/fusebox2.jpg
Old May 22, 2002 | 06:15 PM
PrecisionH23a's Avatar
on my USDM it says...
15A
STOP
HORN
hope that helps out
Old May 23, 2002 | 06:10 AM
Default Re: JDM fuse box layout (GudeH23a)
Thanks Is the box the same - same amount of fuses arranged in the same order? - should be the same fuse if it is...
What would 'Stop' mean?...
Old May 23, 2002 | 07:22 AM
Meccanoman's Avatar
OK Will check the bible when i gt home. am offline till monday as an from 2nite. So you gota hold yer breaath till den unless someoneelse can help in the mean time.
Mek
Old May 27, 2002 | 05:21 AM
Looks like its up to you
kayelemenohpee
Sep 12, 2007 12:32 AM
si0385.
20
Apr 17, 2006 08:12 AM
spammeoff
Nov 15, 2005 03:01 AM
Guitarzann
Dec 30, 2001 10:36 PM
87acc
Dec 25, 2001 04:19 PM
