Quick question about H22 into DC2
Old Mar 4, 2007 | 04:41 PM
ezza's Avatar
Default Quick question about H22 into DC2
Im putting a H22 into my DC2 and i just wondered, you guys who have already done it before, or if you know whats the sump clearance like? i like my cars low and im hoping the H22 will allow this
thanks in advance
Old Mar 4, 2007 | 04:45 PM
downeyballz's Avatar
Default Re: Quick question about H22 into DC2 (ezza)
its much lower than stock, i havent owned one, but seen a few in person and pics.
Old Mar 4, 2007 | 04:46 PM
ezza's Avatar
Default Re: Quick question about H22 into DC2 (downeyballz)
are there any pics where you can clearly see, like from the front or somethin?
Old Mar 4, 2007 | 05:14 PM
JasonST's Avatar
I wouldn't lower it very much at all. I have an h22 dc2 and the h22 headers and oil pan sit much lower than a b series, and if u lower it and go over speed bumps, railroad tracks, or bumps in the road ur ganna scrape the crap outa ur headers and oil pan. my teg is at stock height and I've only scraped the headers once going over a speed bump, not much room for clearance, but I'm sure an inch or so wouldn't be so bad. Also, then u gotta worry about the axles angles being worse, with an h22 they're at a bad angle as it is, if u lower ur car alot it's ganna put more stress on ur axles.
Old Mar 4, 2007 | 06:23 PM
deadline's Avatar
your oil pan will be two inches off the ground with a standard drop....
Old Mar 5, 2007 | 06:16 AM
ezza's Avatar
Default Re: (deadline)
The engine arrived today, i am seriously concidering selling it and gettin a B18c4 wi boost, i HAVE to slam my car!!
Old Mar 5, 2007 | 11:05 AM
Lan's Avatar
Lan
Default Re: (ezza)
You can't ride too low. I had to raise my suspension to clear the header and pan. I have the swap in my DC.
Old Mar 5, 2007 | 12:47 PM
skunked's Avatar
Default Re: (ezza)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ezza &raquo;</TD></TR><TR><TD CLASS="quote">The engine arrived today, i am seriously concidering selling it and gettin a B18c4 wi boost, i HAVE to slam my car!!</TD></TR></TABLE>
then a full H22 swap is not for you. The H2B has good ground clearance
Old Mar 5, 2007 | 01:02 PM
ozzyman's Avatar
Default Re: (skunked)
Ground clearance is always an issue with H22 EG/DC swaps. I have a 3 inch downpipe thats has a pretty good size dent in it. You just have to be alot more careful with this setup. Since I put the 17's on, I havent scraped my oil pan.
huskyl3oi
May 16, 2010 07:15 PM
DCFIVER
May 19, 2007 06:16 PM
EDANSiR
Sep 13, 2006 05:36 PM
vanos_pusha
Feb 12, 2006 03:26 PM
