Removing A/C lines in a crx?
Old Mar 4, 2007 | 11:11 AM
slow91crxdx's Avatar
Default Removing A/C lines in a crx?
I'm sure its harder than I'm making it out to be, but when I put my motor back in my crx I did't bother with the A/C compressor. Now I wanna remove the lines also, anyone ever do this or have knowledge of doing it? I just wanna remove the ones in the engine bay that go to the firewall, Do I just use 2 big wrenchs or what? Also if anyone knows the size of the wrenchs and how to get the lines out, that would be appricated thanks.
Old Mar 4, 2007 | 12:15 PM
jdmcars.com's Avatar
Default Re: Removing A/C lines in a crx? (slow91crxdx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slow91crxdx &raquo;</TD></TR><TR><TD CLASS="quote">, Do I just use 2 big wrenchs or what? .</TD></TR></TABLE>
Yes, assuming your system is already discharged. If you want to properly remove them, disconnect them at the fire wall, then at the front end (there are also some bolts/brackets supporting the lines else where).
If you want to remove the lines as they comeout of from the firewall, that is easy as well. You can by a vent bypass from either the dealer or the junkyard from a Civic/CRX model that didn't have AC.
Old Mar 4, 2007 | 12:24 PM
cbp_crx's Avatar
Default Re: Removing A/C lines in a crx? (jdmcars.com)
yep, unhook them at the firewall, I used 2 cresent wrenches I believe, also you may as well take out the condensor if you are removing the lines, I think it took me about an hour to completely remove the a/c including the lines, wiring, a/c fan etc.
Old Mar 4, 2007 | 12:29 PM
Default Re: Removing A/C lines in a crx? (cbp_crx)
Does the system have to be discharged? I doubt it has any freion or whatever in it, but if it does and I disconnect the lines will it get me? lol, if I do have to have discharge it how do I go about doing it, or do you have to have the A/C machine to do it?
Old Mar 4, 2007 | 12:35 PM
cbp_crx's Avatar
well if you don't have the compressor on the engine anymore, it would be discharged because you would have had to unhook the lines to take it out.
-Championship-
Jan 17, 2007 08:59 PM
e she i
11
Dec 16, 2006 10:06 AM
Rob.
13
Jun 17, 2005 06:42 PM
MTR.18
May 13, 2004 10:18 AM
DC2 to AP2
Apr 11, 2004 11:12 AM
