1 motor mount bad = to replace all ??
Old Mar 4, 2007 | 10:42 AM
Extreez's Avatar
Default 1 motor mount bad = to replace all ??
my passanger side transmission motor mount is bad, and i found one for $50 on ebay, which gives out lifetime warranty, but would i have to replaced them ALL or can i just replace the one thats bad ?
Old Mar 4, 2007 | 10:45 AM
Blackturboteg's Avatar
Default Re: 1 motor mount bad = to replace all ?? (Extreez)
Depending on how worn out the other two are. What year you got? If they are worn i would replace all if they look good , not cracking i wouldnt say u would have to replace all just the one that needs it.
Old Mar 4, 2007 | 11:35 AM
numotive's Avatar
Default Re: 1 motor mount bad = to replace all ?? (Blackturboteg)
I have the same problem... I just ordered an OEM replacement mount for the passenger side tranny mount, as well as a energy polyurethane inserts kit for the rest.
I'm hoping the other mounts won't be too bad and I can just throw the inserts in there. My tranny mount however is completely torn.
Old Mar 4, 2007 | 11:52 AM
Default Re: 1 motor mount bad = to replace all ?? (numotive)
Just make sure to check all the other ones. To check if they need to be replace also if not ur fine.
Old Mar 4, 2007 | 12:04 PM
numotive's Avatar
You should grab some energy suspension polyurethane motor mount inserts since you are going to be replacing the mounts anyway They are only like 40 bucks.
Old Mar 4, 2007 | 12:20 PM
Extreez's Avatar
this is the one im getting http://cgi.ebay.com/ebaymotors...11592 if i get this i dont need any other things do i, just slap it on right ?
mr2
Mar 14, 2016 09:04 AM
Randy4000
Jul 31, 2015 11:30 AM
silas871
Apr 16, 2013 09:29 AM
Backk InTheDA
Aug 3, 2005 11:57 AM
m0t0rhead
Dec 28, 2002 01:31 PM
