Cross-threaded bolt.. Need tap size
OK So i cross-threaded one of the bolts that go into the chassis on my rear suspension.. it is one of the bolts that go where a rear camber kit would go or where you would do the washer trick...
im trying to find out wut size tap i could use to just chase that hole and clean up the threads in there... i only have my dads tap set and it has no metric sizes... so i assume imma have to buy one..and dont want to get the wrong size since i dont have the money for a while set right now.
can anyone help?
EDIT**
also wuts the different between taps like bottom, plug, and Taper
Modified by JRTegman987 at 10:29 PM 3/3/2007
can anyone help?
EDIT**
glad someone knew for sure, i just figured since honda used 1.5 threadpitch for the wheel studs they did for most stuff. good to know, cuz im gonna have to do the washer trick in a few weeks.
E-Rok
Jan 26, 2004 07:59 AM
