full integra brake setup...what do i need?
Old Mar 3, 2007 | 06:12 PM
civic89si666's Avatar
Default full integra brake setup...what do i need?
Ok so i want to put Integra brakes on my 89 Si Hatch. My older brother has a 94 integra thats about to go into the junkyard that hes bringing over tomorrow to do the swap. My questions are what do i need to do both front and rear Integra brakes? also would i be able to still fit my 14 inch CRX Si rims over the brakes? and what do i need to customize to put this set up on my car? I know i need basically the whole rear but with the front im still not sure. Another thing is getting the air out of the system....how should i go about that? i searched some but didnt find a lot other then for sale threads Thanx in advance guys
Old Mar 3, 2007 | 06:32 PM
Default Re: full integra brake setup...what do i need? (civic89si666)
bump it...need to know....should i just do rear disc and keep the fronts the stock Si ones? ive heard the integra set up on the front is a pain when using the integra knuckles...is this true?
Old Mar 3, 2007 | 07:33 PM
dr_latino999's Avatar
You can't use the DC knuckle, geometry = the wrong. Now the rear disc = the right.
http://fourthgenhatch.net/reardiscswap.html
Yes you can fit 14's over the 10.3" brakes (when using the proper knuckle of course)
crazy irishman
Oct 14, 2009 11:32 PM
efrunner09
12
Jan 1, 2009 10:30 AM
89dxhunchback
Jun 5, 2003 11:21 AM
