***CAR WONT START**** NO CEL'S OR CODES NEED HELP!!!!
I JUST PUT A NEW MOTOR IN MY CIVIC 4DR AND I HAVE ALL WIRE HOOKED UP BUT CAR WONT START NO CEL'S OR ECU CODE'S I NEED HELP QUICK
ITS SOUND LIKE THE STARTER IS STUCK BUT MY STARTER IS NEW WOULD IT HELP IF I TOOK OUT THE STARTER AND PUT IT BACK IN I DONT KNOW WHAT IT COULD BE ITS MY DAILY DRIVER PLEASE NEED HELP
HERE THE LINK TO THE VID
http://s82.photobucket.com/alb...2.flv
link to the other side of car
http://s82.photobucket.com/alb...3.flv
THANKS
Modified by Under Con. CrX at 9:01 PM 3/4/2007
Modified by Under Con. CrX at 9:27 PM 3/4/2007
THANKS
well first since it sounds like a starter problem...check all the grounds. There should be one on the valve cover, one on the theromostat housing (very important) and the negative battery wire running to the tranny. Check and clean them then check your battery. Hondas are real tempermental when it comes to batterys. Does it crank or nothing happen at all?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic89si666 »</TD></TR><TR><TD CLASS="quote">check all the grounds. There should be one on the valve cover, one on the theromostat housing (very important) and the negative battery wire running to the tranny. Check and clean them then check your battery.</TD></TR></TABLE>
do u mean a ground from the positive terminal running to the tranny or negative terminal running to the tranny. I have one running from my positive but not negative.
YEAH I CHECKED EVERY THING AND I WAS TOLD ON A NOTHER FORUM IT WAS MY BATTERIE DUE TO THE FACT THAT WHEN ITS FULLY CHARGED IT STILL ONLY READS AT 6 VOLTS SO MY BATTIER MUST BE SHOT GOOD THING I HAVE A GOOD ONE I JUST HAVE TO CHARGE IT BUT YEAH NOTHING AT ALL HAPPENS JUST A CLICK HOPE FULLY ITS THE BATTERIE
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Under Con. CrX »</TD></TR><TR><TD CLASS="quote">YEAH I CHECKED EVERY THING AND I WAS TOLD ON A NOTHER FORUM IT WAS MY BATTERIE DUE TO THE FACT THAT WHEN ITS FULLY CHARGED IT STILL ONLY READS AT 6 VOLTS SO MY BATTIER MUST BE SHOT GOOD THING I HAVE A GOOD ONE I JUST HAVE TO CHARGE IT BUT YEAH NOTHING AT ALL HAPPENS JUST A CLICK HOPE FULLY ITS THE BATTERIE </TD></TR></TABLE>
I guess that would help lol, im running a yellowtop never had a problem
ok turns out it was the starter
so i put a new one in but now the motor wont start here is the video so you can see and here it what it sounds like
thanks i realy need the help
so i put a new one in but now the motor wont start here is the video so you can see and here it what it sounds like http://s82.photobucket.com/alb...2.flv
U sure theres a flywheel in there haha, sounds like the spline is spinning by itself, or its stuck and wont spin.
Well your flywheel is definately not spinning or your timing belt snapped, i would take off the cover under the transmission , that flywheel dust cover, and have someone crank the car and look at the flywheel, OR pull out the starter and catch the ring gear with your finger. if it spins, you need to install a new ring gear or put another flywheel on the engine.
I would try push starting it before all of that other ****
Well it is turning my motor over cus it turns every thing like it should but it dont start i will go take video of the motor truing over but on the other side now
just to clear things up
well heres the vid of the other side to clear things up that its not the fly or start cus my motor is still truning over
are u getting spark or fuel , ur fuel pump priming?, pull a spark plug wire out and put a long bolt inside have someone crank the car and put the bolt near a chassis ground bare metal look for small blue spark.
hope it helps somewhat
well i know i am geting fuel so that must mean that the pump is working wright so then that only leavs me with spark right that could be the only thing wrong here
oh and would time affect this
i didnt but i think the person before me did
and i have some skill on cars but not to the point to where i know how to set time or even check it so IDK i am going to have to wait till tommorrow or some thing
