gsr/ls cluster into a 91 crx help
Old Mar 3, 2007 | 04:23 PM
street-crx's Avatar
Default gsr/ls cluster into a 91 crx help
i did a cluster swap on my crx got everythink wire right and got the electronic speed sensor but my speedometer still not working and my b16 losses vtech because of the check engine light. Did anyone have this problem before or know how to solved, i need help!!!!! thanks.....
Old Mar 3, 2007 | 07:21 PM
dr_latino999's Avatar
Default Re: gsr/ls cluster into a 91 crx help (street-crx)
Did you wire up the VSS properly?
Old Mar 3, 2007 | 10:00 PM
street-crx's Avatar
Default Re: gsr/ls cluster into a 91 crx help (dr_latino999)
yea is wire to ping b16 on the ecu and to ping b6 on the cluster the vss is new just buy fron honda to
Old Mar 7, 2007 | 04:40 PM
street-crx's Avatar
has nobody has this problem with the wiring before?
Old Mar 7, 2007 | 05:14 PM
NastyHabitzCRX's Avatar
Default Re: (street-crx)
just tryin to remeber off the top of my head.
but the orange?, wire for the VSS should just be t'd into at the cluster since it goes to the ecu anyways.
thats the way i did mine and works fine
4LugR
Jan 22, 2011 07:02 PM
ALLMOTOR CRX
Feb 1, 2007 02:01 PM
I LOVE MY EF9
Jan 18, 2004 10:01 PM
All_Motor EF9
Jan 4, 2004 05:29 PM
