suspension techniques rear sway bar with aftermarket lcas
Old Mar 3, 2007 | 03:30 PM
fullsleeves's Avatar
Default suspension techniques rear sway bar with aftermarket lcas
I wanted to see if anyone has any pictures of how the endlinks mount onto aftermarket lcas
Old Mar 3, 2007 | 03:44 PM
Eran's Avatar
HT White Ops
They don't mount to the LCA's. They mount to the shocks. Check my sig.
Old Mar 3, 2007 | 04:29 PM
Otherguy's Avatar
NASIOC.com
Default Re: (Eran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran &raquo;</TD></TR><TR><TD CLASS="quote">They don't mount to the LCA's. They mount to the shocks. Check my sig.
You are wrong my friend, they should mount to the LCA and not the shocks like you have them
Old Mar 3, 2007 | 04:33 PM
Eran's Avatar
HT White Ops
Default Re: (Otherguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Otherguy &raquo;</TD></TR><TR><TD CLASS="quote">
You are wrong my friend, they should mount to the LCA and not the shocks like you have them</TD></TR></TABLE>
I'm wrong?
Yeah, I guess I am. I didn't purchase a brand new ST rear swaybar. I didn't just install an ST rear swaybar. I didn't just do a writeup on how to install an ST swaybar. I don't have the instructions in front of me. I didn't get those L-brackets with the kit.
You're a retard. Shut the fvck up if you don't know what you're talking about.
Old Mar 3, 2007 | 04:39 PM
blinx9900's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Otherguy &raquo;</TD></TR><TR><TD CLASS="quote">You are wrong my friend, they should mount to the LCA and not the shocks like you have them</TD></TR></TABLE>
idiot, how can you say he is wrong, did you not see the pic? st makes more than one type of rear sway bar, your friend must have a different one, probably the st speedtech setup.
Old Mar 3, 2007 | 04:53 PM
Default Re: (blinx9900)
Thanks for you help, and great install writeup, makes a lot more sense now!!!
Old Mar 4, 2007 | 06:57 AM
Eran's Avatar
HT White Ops
Default Re: (fullsleeves)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fullsleeves &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for you help, and great install writeup, makes a lot more sense now!!!</TD></TR></TABLE>
Glad to be of service
Old Mar 4, 2007 | 07:06 AM
excivicboy96's Avatar
Default Re: (Eran)
do you think it performs better when its mounted there? better than directly to the lca?
Old Mar 4, 2007 | 05:46 PM
blinx9900's Avatar
Default Re: (excivicboy96)
there shouldent be a difference, i guess there is more force on the sway bar the further its mounted out, not sure what that would do for handling though.
Old Mar 5, 2007 | 02:15 PM
Malakai's Avatar
u think that l bracket would ever move or get turned?
Old Mar 5, 2007 | 03:31 PM
EK9Greg's Avatar
Default Re: (Eran)
I'm not saying you are right or wrong I am just gonna put in a note Most sway bars bolt to the LCA but they do make sway bars that mount to the shock point when the car doesn't come with a stock sway bar. Cars that don't come with sway bars normally don't have the spot to mount the sway bar. Thats all I have to say about that.
Another note I've had sway bars that mount both ways and I never noticed the difference between the 2
Old Mar 5, 2007 | 05:17 PM
trrbl1bmx's Avatar
The pic is for stock LCA's with no sway bar mount. If you have an endlink mount on your LCA you should use it. There is a great deal of flex like you have it in the pic, which is nothing on a street car, but definatley not something you want to do on track. I myself have an ST sway on one of my EF's and it came with those brackets. Just depends on your setup.
Old Mar 5, 2007 | 06:16 PM
Eran's Avatar
HT White Ops
Default Re: (p00n)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by p00n &raquo;</TD></TR><TR><TD CLASS="quote">The pic is for stock LCA's with no sway bar mount. If you have an endlink mount on your LCA you should use it. There is a great deal of flex like you have it in the pic, which is nothing on a street car, but definatley not something you want to do on track. I myself have an ST sway on one of my EF's and it came with those brackets. Just depends on your setup.</TD></TR></TABLE>
That bar can't be used with a traditional style endlink. There is no endlink I could use on my LCA that would work with that bar, it just mounts too far out. The only ST bars that don't mount like this for Civics is the Speedtech one with the subframe brace. I can't see how there'd be any more flex with a vertical stacked endlink than with a dual-pivot endlink, such as the ones that come stock with the CTR. Hell, even the Function7/Aurora/BLOX endlinks have the ability to flex more than these, you a bolt through an eyelet.
As to that bracket moving, it'd have to be enough lateral force to move BOTH of the brackets.
Old Mar 5, 2007 | 06:27 PM
charjacq's Avatar
New User
Default Re: (EK9Greg)
That doensn't look like it's tight enough....
Old Mar 5, 2007 | 06:33 PM
Eran's Avatar
HT White Ops
Default Re: (charjacq)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by charjacq &raquo;</TD></TR><TR><TD CLASS="quote">That doensn't look like it's tight enough....</TD></TR></TABLE>
Duh
That's before it was torqued to 40 lb/ft ... the same torque specs as your LCA bolts.
Old Mar 23, 2007 | 09:12 PM
Layziejoe775's Avatar
Default Re: (Eran)
bump
Old Mar 23, 2007 | 09:23 PM
Eran's Avatar
HT White Ops
Default Re: (Layziejoe775)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Layziejoe775 &raquo;</TD></TR><TR><TD CLASS="quote">bump</TD></TR></TABLE>
Why did you bump this thread?
Old Mar 23, 2007 | 09:32 PM
astroxtc's Avatar
Default Re: (Eran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran &raquo;</TD></TR><TR><TD CLASS="quote">Why did you bump this thread?</TD></TR></TABLE>
so it can be bump ttt on my recent topics lol
where can i get my hands on one of those st rear sways?
Old Mar 23, 2007 | 09:35 PM
Eran's Avatar
HT White Ops
Default Re: (astroxtc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by astroxtc &raquo;</TD></TR><TR><TD CLASS="quote">
where can i get my hands on one of those st rear sways?</TD></TR></TABLE>
But you didn't bump it, the stillborn did.
You can get one from Summit Racing
helicopter201
Jan 19, 2009 10:10 AM
b16_madman
Jan 9, 2007 01:21 PM
Sean @ ESG
30
Sep 28, 2005 12:44 AM
BassBoy19
Dec 28, 2003 09:43 PM
performula
Dec 13, 2002 08:27 AM
