FS: Drag Gen 3 Turbo Kit for B Series
For sale is a used Drag Gen 3 turbo kit, which I am selling for my bro. This kit was purchased last year and has approx. 2500 miles (car was only driven on the weekends). Just an example of what this kit can do... On a Dynojet at 8.7psi this kit made around 270whp 180wtq on a completely stock 98 GSR. For all you locals who want to pick up, I am located in Yuba City, CA which is 50 miles north of Sacramento. I will ship but at the buyer's expense.
$1700 firm
NOTE: The intercooler piping with this kit is made to fit B-series motors with a Type R Intake manifold...so all brands of Type R style intake manifolds will work. (kit was being used with a Skunk2 IM)
The kit includes:
- T3/T4 .57 trim Turbonetics Turbo with polished turbo housing
- Drag High flow 4 into 1 cast iron turbo exhaust manifold
- Drag wastegate dump tube
- Drag mandrel bent 2.5" high flow exhaust down pipe with flange already welded on
- Tial Wastegate .38mm with .6 bar spring (polished)
- HKS Blow off valve
- Drag High Flow front mount intercooler with polished cast aluminum end tanks
- Walbro 255 High pressure/High volume intank fuel pump
- Goodrich stainless steel braided oil feed line with fittings
- Drag mandrel bent high flow chrome plated intercooler pipes
- Russle stainless steel braided oil return line
- Drag Blue silicone hose and hose clamps
- K&N filter with intake assembly
- All necessary hardware and fittings
- All necessary hose and hose clamps
- All necessary gaskets
Click on images below for a larger image
Modified by PYITR821 at 1:25 AM 3/17/2007
Modified by PYITR821 at 1:27 AM 3/17/2007
$1700 firm
The kit includes:
