a6 distributor help needed!
Old Mar 3, 2007 | 10:05 AM
posaccord01's Avatar
Default a6 distributor help needed!
i'm pretty sure about this but jus had to make sure...i can only use an a6 distributor on the a6 motor right? some guy on my local forum was saying i could use a 90-93 teg distributor and jus cut the leg. help appreciated...
jon
Old Mar 3, 2007 | 03:24 PM
jlicrx's Avatar
Default Re: a6 distributor help needed! (posaccord01)
you can use the D16A6 distributor from the 88-91 CRX Si, 88-91 CRX HF, 89-91 Civic Si or 90-91 Civic EX
Old Mar 3, 2007 | 06:28 PM
97grnrs's Avatar
Default Re: a6 distributor help needed! (jlicrx)
u can pretty much use any obd0 distributor that u can get to fit.. i use a integra ls one.. i did have to notch one leg to set timing but it will work ..
Old Mar 3, 2007 | 07:30 PM
dr_latino999's Avatar
Default Re: a6 distributor help needed! (97grnrs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97grnrs &raquo;</TD></TR><TR><TD CLASS="quote">u can pretty much use any MPFI obd0 distributor that u can get to fit..</TD></TR></TABLE>
Old Mar 22, 2007 | 03:59 PM
roadrunner1's Avatar
Default Re: a6 distributor help needed! (dr_latino999)
so you could use a 1.5 dizzy on the 1.6 and it will work fine?
kevcha711
Jan 21, 2010 09:50 PM
dohdoh420
Jun 8, 2006 05:54 AM
Badass240SX
Dec 5, 2004 08:37 PM
soundman
May 8, 2003 06:38 AM
Sirex
Mar 18, 2003 07:31 PM
