SRS light
Old May 21, 2002 | 08:56 PM
FortunateFool.'s Avatar
Default SRS light
my SRS light under my guages is on all the time. i recently took out my interior to do my sound deadening stuf (yes i know add weight, but i compete in sq competitions) anyways. so im guessing i unhooked something. but i re did everything and the light is still on. what woudl be causing this to happen?
thanks,
jc
Old May 21, 2002 | 09:15 PM
GapxGuy's Avatar
Sushi Buffet Champion
Default Re: SRS light (jcstites)
I had that for a while too...then I unpluged the bulb.
Old May 22, 2002 | 08:40 AM
Default Re: SRS light (GapxGuy)
anybody else? i hope it doesnt mean that my air bags wont work
Old May 22, 2002 | 08:42 AM
DOHCtorTHRUST's Avatar
try disconnecting the battery and disconnect the srs module under the center dash(near your gas pedal) i've never done it but i think that should work....
Old May 22, 2002 | 09:32 AM
KRiS1's Avatar
I got lucky, went to the dealer and they reset the light for free.
Old May 22, 2002 | 09:39 AM
oldB18EF's Avatar
gap, howd you turn ur bulb off? Take the cluster apart?
Old May 22, 2002 | 09:46 AM
NWPNOMORE's Avatar
Banned
Default Re: SRS light (WRCivicsSiandEX)
remove the cluster, then remove the bulb, that's all you gotta do.
Old May 22, 2002 | 09:51 AM
4g4me's Avatar
I think that honda may have to fix any safety restraint problem, you shoud at least ask. I know that if there is a probem with your seatbelt, honda must not fix, but replace all affected parts. I brought my 88 hatch in because the seatbelt would not retract properly , and they replaced the whole assembly. SRS is a serious, I would not just pull the bulb, an airbag used in any other way besides when it is supposed to can be dangerous if not fatal. Try the dealership.
Old May 22, 2002 | 07:14 PM
Default Re: SRS light (4g4me)
thanks guys. ill get the dealership to check it out.
Old May 22, 2002 | 07:39 PM
oldB18EF's Avatar
just installed my momo wheel today
i just put electrical tape cut to the shape of the light and taped over that worked now just gotta figure out how to wire up this horn
Old May 22, 2002 | 07:52 PM
ic0n's Avatar
srs light is on, it must deal with da airbag
1clean01
Honda Civic (2001 - 2005)
Jan 18, 2015 04:25 PM
Bleakened
Dec 12, 2014 12:29 PM
electro706
Jan 22, 2005 08:53 AM
xMuGeNxDc5x
Aug 6, 2004 02:15 PM
hzemall
Mar 27, 2003 08:13 PM
